largest tire wheel on a 72 rr with mini tub and relocation? #1987066
01/09/16 07:22 PM
01/09/16 07:22 PM
texas
462hemi Offline OP
462hemi  Offline OP
texas
i have done some reading and it looked like someone on the tubbed thread was saying something about fitting a 15x14 rear wheel on a 72 road runner with a mini tub and the springs relocated to the framewell......can anyone confirm or correct this? what is the largest wheel/tire combo possible?
462 gen 3 hemi daily driven
Re: largest tire wheel on a 72 rr with mini tub and relocation? [Re: 462hemi] #2005663
02/04/16 08:52 PM
02/04/16 08:52 PM
texas
462hemi Offline OP
462hemi  Offline OP
texas
anyone have any input here? surely some of you guys have done this before. any input at all would be helpful
Re: largest tire wheel on a 72 rr with mini tub and relocation? [Re: 462hemi] #2005805
02/05/16 12:02 AM
02/05/16 12:02 AM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Have 295 width on a 72 Charger with springs relocated, no sheet metal work with an inch on each side. 12" cross section width on 10" wheels. Backspacing is critical.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: largest tire wheel on a 72 rr with mini tub and relocation? [Re: 462hemi] #2006046
02/05/16 01:27 PM
02/05/16 01:27 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The wheel wells are pretty big on these cars, they go to flush with the frame rail. The leaf spring will be your limiting factor way before the tubs become an issue.
Re: largest tire wheel on a 72 rr with mini tub and relocation? [Re: 462hemi] #2006108
02/05/16 03:14 PM
02/05/16 03:14 PM
Springfield, MO
Steve88 Offline
Steve88  Offline
Springfield, MO
I don't have any mods done to my 71 at all and I have 18X11 wheels with a 28x12.50x18 Mickey Thompson Sportsman SR Radials on the rear with no rubbing at all. The wheelwells are huge and if I relocated the springs I would think that there would be another 3" to be had pretty easily.
Re: largest tire wheel on a 72 rr with mini tub and relocation? [Re: 462hemi] #2006369
02/05/16 11:18 PM
02/05/16 11:18 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Steve88, your car looks incredible!
My Dad had a 340 '71 RR, he ran a good sized McCreary tire on the back with no modifications, it's amazing how much tire will fit on these B-bodies.
Re: largest tire wheel on a 72 rr with mini tub and relocation? [Re: 462hemi] #2006689
02/06/16 01:26 PM
02/06/16 01:26 PM
USA
Hooligan Offline
Hooligan  Offline
USA
Well, if no one chimes in with an example that satisfies your question, just do what I did. Pick the tire and wheel combo that you want, and get their specs on the internet. Tirerack.com is a good choice, and for the wheels, search the manufacturer's website. Then you can make cardboard templates to position in your wheel wells... taking into account, any modifications to the tubs and leaf springs that you want to make, and suspension travel. If the combo that you chose is too large, pick another until you find one that fits just right. It's easy to do. Some company sells an adjustable gizmo that bolts to your axle for mock ups, but if you are only doing this one time, save your money. Sounds like I know what I am talking about, doesn't it?
Re: largest tire wheel on a 72 rr with mini tub and relocation? [Re: 462hemi] #2007678
02/08/16 12:29 AM
02/08/16 12:29 AM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I want to know this info because my rear tires look puny under there.
I'd like to minitub mine, I have a dana60 that is stock length but I will narrow it.
Re: largest tire wheel on a 72 rr with mini tub and relocation? [Re: 462hemi] #2007705
02/08/16 01:02 AM
02/08/16 01:02 AM
Manitoba, Canada
Manitoba, Canada
What size do you want to run? I measured one time and 325/50/15's would fit with custom backspacing rims. They're roughly 13.2" from bulge to bulge if memory serves.
Re: largest tire wheel on a 72 rr with mini tub and relocation? [Re: 462hemi] #2008245
02/08/16 11:03 PM
02/08/16 11:03 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I love this old school look too
