SETTING PINION DEPTH............
#2005628
02/04/16 08:04 PM
02/04/16 08:04 PM
Thumperdart
State of confusion
The guy that was going to set up my carrier can`t so I may just tackle it myself. After talkin to Cab he explained a pinion checker tool should be used but is there another way a guy like me could get the same results?
Re: SETTING PINION DEPTH............
[Re: Thumperdart]
#2005639
02/04/16 08:23 PM
02/04/16 08:23 PM
Posts: 5,163 CT
GTX MATT
CT
Thumper RA Tech sells pinion depth checkers that are less than 300 bucks, they sit between on the pinion head and you measure against the carrier bores a certain way to check depth, using the depth indicator on a pair of veneer calipers. I just bought one to use on my 8 3/4. I'm sure it won't be perfect, but will give you a good start, then adjust based on the pattern. People with the high dollar mics say they often need to adjust based on the pattern anyway, as the depth from the manufacturer isn't quite perfect. You can buy the tool on summit and they're application specific. Reviews on them have been pretty good. http://www.summitracing.com/parts/rat-10007/overview/
[Re: BuckeyeBrawler]
#2005655
02/04/16 08:44 PM
02/04/16 08:44 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
You can go the trial and error method... Using the old pinion depth shim assemble the unit. Set the backlash to the indicated amount check the match. Move the pinion depth according to the pattern left. Remember to add some type of drag to the pinion while rotating to set the pattern.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2005660
02/04/16 08:49 PM
02/04/16 08:49 PM
Thumperdart
State of confusion
Thankxx guys not sure yet what I`ll do but appreciate the input........ I don`t want to tear apart the old unit as it`s for sale.......
[Re: Thumperdart]
#2005684
02/04/16 09:18 PM
02/04/16 09:18 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Have Cass send you a reemed pinion bearing that will slide on and off. If you have that, an assortment of shims and yellow gear marking compound, and a dial indicator to verify backlash, you have all you should need.
EDIT: Forgot you also need a spanner tool. I have one I'd be happy to lend you if needed, Dom. Let me know.
[Re: Thumperdart]
#2005694
02/04/16 09:31 PM
02/04/16 09:31 PM
Posts: 9,857 MI, usa
dvw
MI, usa
I have a checker but don't usually use it. Start with the original shim. Check the pattern. Best tutorial I've seen is here. Click and scroll down to general instructions. https://www.yukongear.com/manuals.aspxDoug
[Re: Thumperdart]
#2005696
02/04/16 09:33 PM
02/04/16 09:33 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have depth checkers but rarely bother to use them. They will usually get you close, but normally the shim pack will need to be adjusted some to get the pattern dead nuts. If you are replacing gears, start with the one that came out. On a new assembly, chose an initial shim pack thickness to start according to what rear is being set up and go from there. The pattern will determine where to go with it.
[Re: StealthWedge67]
#2005701
02/04/16 09:39 PM
02/04/16 09:39 PM
Thumperdart
State of confusion
EDIT: Forgot you also need a spanner tool. I have one I'd be happy to lend you if needed, Dom. Let me know. Figured I could get a bearing locally and hone it out but Cab explained and I read that there`s a small margin of error .+004 -001 in terms of the pinion location to start w/then you shoot for the pattern.........
[Re: Thumperdart]
#2005704
02/04/16 09:48 PM
02/04/16 09:48 PM
Thumperdart
State of confusion
Autozone has pinion bearings in stock that I can butcher for $7.90 then after the depth and pattern are good, then I need to tighten the pinion nut(me)and check preload on the pinion and measure how many in. lbs to turn it correct?
[Re: GTX MATT]
#2005710
02/04/16 09:58 PM
02/04/16 09:58 PM
Thumperdart
State of confusion
Thumper RA Tech sells pinion depth checkers that are less than 300 bucks, they sit between on the pinion head and you measure against the carrier bores a certain way to check depth, using the depth indicator on a pair of veneer calipers. I just bought one to use on my 8 3/4. I'm sure it won't be perfect, but will give you a good start, then adjust based on the pattern. People with the high dollar mics say they often need to adjust based on the pattern anyway, as the depth from the manufacturer isn't quite perfect. You can buy the tool on summit and they're application specific. Reviews on them have been pretty good. http://www.summitracing.com/parts/rat-10007/overview/ You said $300 bucks that thing`s 25 and change and if it helps, it may be a new tool in my box.........
[Re: Thumperdart]
#2005716
02/04/16 10:20 PM
02/04/16 10:20 PM
StealthWedge67
Puyallup, WA
The Richmod gears that Cass sent me last month had a spec for pinion depth to be measured at the head-face of the gear. I started with .090 under the pinion and just checked this with a simple caliper. Measurement was within a few thousandths of spec, so I moved on to looking at the pattern and fine-tuning that with the side adjusters.
[Re: Thumperdart]
#2005718
02/04/16 10:21 PM
02/04/16 10:21 PM
Posts: 235 Gilbert AZ
tsanchez
Gilbert AZ
I have had the depth tool and after a while I quit using them, its easier for me to just set it up how I know and then adjust for the pattern, I make setup bearings for the ones that have shims behind them, or setup races for those in the case. I always start with a good known pinion shim dimension, if you look online Im sure there is a chart handy. then set pinion preload by feel without shims or crush washer, smack lightly the pinion back and forth to set races and bearings and put carrier in, set backlash, I use .006 for most some looser but I use the same so patterns will not be affected differently. Adjust pinion depth to center pattern in gear face to flank, heel to toe is not really adjustable as it is how the gear is made and run in. Then after set up go back and set pinion preload with a inch pounds wrench or I do it by feel and shim accordingly or use the crush washer. If using crush washer I locktite the pinion nut.
[Re: 383man]
#2005861
02/05/16 01:06 AM
02/05/16 01:06 AM
Thumperdart
State of confusion
Although this sounds a bit tricky I HOPE I can get it right and not fubar it.........lol! So just one pinion set up bearing?
