Anybody use MRL roller lifters in their LA small blocks? #2002810
01/31/16 06:16 PM
01/31/16 06:16 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
I have a very nice 360 build that I did last year and want to step up to a roller cam. I didn't tube this block and like I said its already assembled so are these direct fit without any grinding and can they be used without oiling mods to the lifter galleys? I did LOTS of block grinding last year to use the comps (828-16). If so I'd like to get a set and button this engine up.
http://www.mrlperformance.com/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: pittsburghracer] #2002839
01/31/16 07:15 PM
01/31/16 07:15 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Got them in both my 440 W2 and my 414. Just drop in and Go. Super light too, i used the .185 offset intake cups which helped straighten out the pushrod on the W2's. Got the big wheels with the forced axle oiling on both sets.
WIZE
In Car:
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: pittsburghracer] #2002854
01/31/16 07:39 PM
01/31/16 07:39 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: justinp61] #2002891
01/31/16 08:52 PM
01/31/16 08:52 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have used these in a stock block. They are now in my 340 block that has been bushed.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: pittsburghracer] #2002914
01/31/16 09:27 PM
01/31/16 09:27 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Didn't MRL work with Comp to develop these lifters?
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: Rob C] #2002926
01/31/16 09:41 PM
01/31/16 09:41 PM
PA.
"Little"John
"Little"John
PA.
I thought I remembered Brian saying he helped on someone's roller lifters to ease use
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: pittsburghracer] #2002951
01/31/16 10:08 PM
01/31/16 10:08 PM
Idaho
LaRoy Engines Offline
Idaho
MRL lifters dropped right in the 426/360 we built, no block grinding at all. He has standard and pressure fed rollers. The pressure fed rollers poured a lot of oil on the camshaft with our unbushed lifter bores. Recommend observing pre-lube with intake manifold off.
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: Streetwize] #2003001
01/31/16 10:59 PM
01/31/16 10:59 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
did you run it yet with the offsets? 59* block?
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: pittsburghracer] #2003026
01/31/16 11:27 PM
01/31/16 11:27 PM
NC
barracuda man Offline
NC
Been running the doug herbert sbm solid roller lifters for 3 years and no problems.drop right in. Great price @ $359. up
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: pittsburghracer] #2003099
02/01/16 12:43 AM
02/01/16 12:43 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I was told by a very sharp and respected small block guy to not run lifters with an off set cup in my build. I didn't, I also didn't ask why.
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: LaRoy Engines] #2003148
02/01/16 01:37 AM
02/01/16 01:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah those pressure fed ones have a .026 edm hole
in them.. it was larger than I was told.. they do
dump a lot of oil
wave
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: justinp61] #2003155
02/01/16 01:46 AM
02/01/16 01:46 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
It will snap the link bar. Puts it into a bind when in a 59 setup.
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: Hot 340] #2003168
02/01/16 01:58 AM
02/01/16 01:58 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Incant see the link bar binding, not with the large diameter roller and ( to me) a straighter pushrod will have less oscillation than one that is at a severe lateral angle ( such as a w2) my 440 w2 is running with them just fine.
Arent the Herbert house lifters morels? They are fine but they are pretty heavy compared to the MRLs. I think the morel solids are the same long body they use for the hydraulic rollers so you have a long lifter body but a comparatively short pushrod. I run pushrod oiling with a nearly but not quite totally restricted shaft oiling, its gone 7200 with ease on my 414 so far.
WIZE
In Car:
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: pittsburghracer] #2003211
02/01/16 03:43 AM
02/01/16 03:43 AM
Queensland Australia
moparmacka Offline
moparmacka  Offline
Brad Miller makes an awesome lifter. Mike at MRL put a heck of lot of R&D into these lifters with Brad. I have a 59 deg Mopar 340 resto/Siamese block with W5's. These blocks have super thick and high lifter bosses and unfortunately because of this, too much clearencing was required for 3/8 pushrods and 180 offset intake seat lifters. However, centre/centre pushrod seats would require minimal clean up with a die grinder between the lifter bores to clear the tie bar. On a factory block, I don't think there would be any issues though.
Did I say how awesome these lifters look and are designed. If the exchange rate wasn't so crappy at the moment I would definately invest in another set. I would most likely go the bushed over needle rollers next time for a few more $'s.
Have also used the Comp 8043-16 with no issues. On appearance, oil band location and quality, the the BAM/MRL lifters are a teir above.
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: moparmacka] #2003299
02/01/16 12:22 PM
02/01/16 12:22 PM
PA.
"Little"John
"Little"John
PA.
GREAT info guys thanks. I am leaning towards these, MRL SBM Pro Sport $505 Available in Standard Pushrod Seats and will probably be ordering this week.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: pittsburghracer] #2003353
02/01/16 01:27 PM
02/01/16 01:27 PM
Renton Washington
Triple Threat Offline
Renton Washington
I put over 600 runs in 3 seasons on my comp 8043-16 roller lifters. Those are the drop in lifters IMM helped comp develop. I ran them in my R3 block so I can't comment on fitment in a stock application.
Comp will rebuild them for ~$11 a lifter which is nice for people who put lots of laps on stuff.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Anybody use MRL roller lifters in their LA small blocks? [Re: pittsburghracer] #2003374
02/01/16 01:55 PM
02/01/16 01:55 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The Comps have one pressurized passage for axle oiling. I think I read somewhere the MRLs have four. Is this correct?
I went with the comps because I figured if they ever needed rebuilt Comp would still be around.
