Anybody use MRL roller lifters in their LA small blocks?
#2002810
01/31/16 06:16 PM
01/31/16 06:16 PM
Posts: 20,193 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have a very nice 360 build that I did last year and want to step up to a roller cam. I didn't tube this block and like I said its already assembled so are these direct fit without any grinding and can they be used without oiling mods to the lifter galleys? I did LOTS of block grinding last year to use the comps (828-16). If so I'd like to get a set and button this engine up. http://www.mrlperformance.com/
Re: Anybody use MRL roller lifters in their LA small blocks?
[Re: pittsburghracer]
#2002839
01/31/16 07:15 PM
01/31/16 07:15 PM
Posts: 9,881 Weddington, N.C.
Streetwize
Weddington, N.C.
Got them in both my 440 W2 and my 414. Just drop in and Go. Super light too, i used the .185 offset intake cups which helped straighten out the pushrod on the W2's. Got the big wheels with the forced axle oiling on both sets.
[Re: justinp61]
#2002891
01/31/16 08:52 PM
01/31/16 08:52 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have used these in a stock block. They are now in my 340 block that has been bushed.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Rob C]
#2002926
01/31/16 09:41 PM
01/31/16 09:41 PM
Posts: 20,193 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Didn't MRL work with Comp to develop these lifters? I thought I remembered Brian saying he helped on someone's roller lifters to ease use
#2002951
01/31/16 10:08 PM
01/31/16 10:08 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
MRL lifters dropped right in the 426/360 we built, no block grinding at all. He has standard and pressure fed rollers. The pressure fed rollers poured a lot of oil on the camshaft with our unbushed lifter bores. Recommend observing pre-lube with intake manifold off.
[Re: Streetwize]
#2003001
01/31/16 10:59 PM
01/31/16 10:59 PM
Posts: 3,396 Pa
Hot 340
Pa
Got them in both my 440 W2 and my 414. Just drop in and Go. Super light too, i used the .185 offset intake cups which helped straighten out the pushrod on the W2's. Got the big wheels with the forced axle oiling on both sets. did you run it yet with the offsets? 59* block?
[Re: LaRoy Engines]
#2003148
02/01/16 01:37 AM
02/01/16 01:37 AM
Posts: 52,972 Romeo MI
MR_P_BODY
MRL lifters dropped right in the 426/360 we built, no block grinding at all. He has standard and pressure fed rollers. The pressure fed rollers poured a lot of oil on the camshaft with our unbushed lifter bores. Recommend observing pre-lube with intake manifold off. Yeah those pressure fed ones have a .026 edm hole in them.. it was larger than I was told.. they do dump a lot of oil
[Re: justinp61]
#2003155
02/01/16 01:46 AM
02/01/16 01:46 AM
Posts: 3,396 Pa
Hot 340
Pa
I was told by a very sharp and respected small block guy to not run lifters with an off set cup in my build. I didn't, I also didn't ask why. It will snap the link bar. Puts it into a bind when in a 59 setup.
#2003211
02/01/16 03:43 AM
02/01/16 03:43 AM
Posts: 370 Queensland Australia
moparmacka
Brad Miller makes an awesome lifter. Mike at MRL put a heck of lot of R&D into these lifters with Brad. I have a 59 deg Mopar 340 resto/Siamese block with W5's. These blocks have super thick and high lifter bosses and unfortunately because of this, too much clearencing was required for 3/8 pushrods and 180 offset intake seat lifters. However, centre/centre pushrod seats would require minimal clean up with a die grinder between the lifter bores to clear the tie bar. On a factory block, I don't think there would be any issues though. Did I say how awesome these lifters look and are designed. If the exchange rate wasn't so crappy at the moment I would definately invest in another set. I would most likely go the bushed over needle rollers next time for a few more $'s. Have also used the Comp 8043-16 with no issues. On appearance, oil band location and quality, the the BAM/MRL lifters are a teir above.
[Re: moparmacka]
#2003299
02/01/16 12:22 PM
02/01/16 12:22 PM
Posts: 20,193 PA.
pittsburghracer
"Little"John
"Little"John
PA.
GREAT info guys thanks. I am leaning towards these, MRL SBM Pro Sport $505 Available in Standard Pushrod Seats and will probably be ordering this week.
#2003353
02/01/16 01:27 PM
02/01/16 01:27 PM
Triple Threat
Renton Washington
I put over 600 runs in 3 seasons on my comp 8043-16 roller lifters. Those are the drop in lifters IMM helped comp develop. I ran them in my R3 block so I can't comment on fitment in a stock application.
Comp will rebuild them for ~$11 a lifter which is nice for people who put lots of laps on stuff.
