hughes rocker shaft sets
#1998174
01/25/16 02:49 AM
01/25/16 02:49 AM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
are the hughes shaft rockers a good set up ? any advice from experience ? any specific things to do when using them? I plan on using a set with 1;5 ratio on a 512 stroker engine with a mild .530" .540" lift /235* on 114 c/l hyd cam. 150 on the seat and 350 on the nose with 6500 max rpms.. kept the whole top end with hughes for compatibility ..pretty much street use. thanks in advance !!
Re: hughes rocker shaft sets
[Re: ek3]
#1998472
01/25/16 04:15 PM
01/25/16 04:15 PM
Posts: 4,457 Washington
madscientist
Washington
A ductile iron rocker would work with that cam.
Make sure the geometry is CORRECT.
[Re: ek3]
#1998487
01/25/16 04:34 PM
01/25/16 04:34 PM
Posts: 200 midwest
superchuck
On thin ice
On thin ice
midwest
I run the hughes 1.6's on two cars. They work great. My cam is .568 lift around 240@ .50 107 CL. I beat the snot out of my cars, No problems
[Re: 383man]
#1998873
01/26/16 05:55 AM
01/26/16 05:55 AM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
These are Hughes 1.6 rockers with their shafts and hold down kit that I bought in early 2011. They have worked flawless as I am very happy with them. Ron I'm happy with them too but unhappy with their billet hold down kit. The (new) version I bought 2 years or so ago require LOTS of shims on the rocker shaft and it doesn't look very professional...
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
[Re: ek3]
#1999467
01/27/16 12:15 AM
01/27/16 12:15 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Yes another tick for Hughes rockers, I have them on a 528 with 730 lift solid roller, love them.
1963 Plymouth Max Wedge 1971 Barracuda
