hughes rocker shaft sets #1998174
01/25/16 02:49 AM
01/25/16 02:49 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline OP
ek3  Offline OP
E
are the hughes shaft rockers a good set up ? any advice from experience ? any specific things to do when using them? I plan on using a set with 1;5 ratio on a 512 stroker engine with a mild .530" .540" lift /235* on 114 c/l hyd cam. 150 on the seat and 350 on the nose with 6500 max rpms.. kept the whole top end with hughes for compatibility ..pretty much street use. thanks in advance !!
Re: hughes rocker shaft sets [Re: ek3] #1998205
01/25/16 04:08 AM
01/25/16 04:08 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Which cylinder heads are you using?
Re: hughes rocker shaft sets [Re: Jeremiah] #1998306
01/25/16 12:35 PM
01/25/16 12:35 PM
E
ek3 Offline OP
ek3  Offline OP
E
915 's
Re: hughes rocker shaft sets [Re: ek3] #1998472
01/25/16 04:15 PM
01/25/16 04:15 PM
Washington
madscientist Offline
Washington
A ductile iron rocker would work with that cam.
Make sure the geometry is CORRECT.
Re: hughes rocker shaft sets [Re: ek3] #1998487
01/25/16 04:34 PM
01/25/16 04:34 PM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
I run the hughes 1.6's on two cars. They work great. My cam is .568 lift around 240@ .50 107 CL. I beat the snot out of my cars, No problems
Re: hughes rocker shaft sets [Re: ek3] #1998584
01/25/16 07:46 PM
01/25/16 07:46 PM
AndyF Offline
AndyF  Offline
The Hughes rocker arm kits are really good parts for the money.
Re: hughes rocker shaft sets [Re: ek3] #1998680
01/25/16 10:16 PM
01/25/16 10:16 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
These are Hughes 1.6 rockers with their shafts and hold down kit that I bought in early 2011. They have worked flawless as I am very happy with them. Ron
Re: hughes rocker shaft sets [Re: 383man] #1998873
01/26/16 05:55 AM
01/26/16 05:55 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
I'm happy with them too but unhappy with their billet hold down kit. The (new) version I bought 2 years or so ago require LOTS of shims on the rocker shaft and it doesn't look very professional...
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: hughes rocker shaft sets [Re: 383man] #1999076
01/26/16 04:12 PM
01/26/16 04:12 PM
E
ek3 Offline OP
ek3  Offline OP
E
have you used the 1.5 's under stock valve covers ?
Re: hughes rocker shaft sets [Re: ek3] #1999385
01/26/16 11:11 PM
01/26/16 11:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They are 1.6 rockers and I had them under these covers for a good while.
My holddown kit sounds different then the newer Hughes kits as I did not have to use hardly any shims with this kit. Ron
Re: hughes rocker shaft sets [Re: ek3] #1999467
01/27/16 12:15 AM
01/27/16 12:15 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yes another tick for Hughes rockers, I have them on a 528 with 730 lift solid roller, love them.
1963 Plymouth Max Wedge
1971 Barracuda
