Slicks, Best brand for stability at speed #199731
01/21/09 12:42 AM
01/21/09 12:42 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Since I guess nobody makes or at least I cant seem to find a 28x10 radial slick (not street radial, full racing slick); is any one brand of bias slick more stable at speed than others?
In the past Ive only used MT slicks. I had a set of 26X8s that were way squirrely on top. Set of 28x10s that werent near as bad.
Just looking for some opinions.
Thanks as usual.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Slicks, Best brand for stability at speed [Re: Von] #199732
01/21/09 12:48 AM
01/21/09 12:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you had enough air in it and you still felt it
was loose on the top end go with a stiff sidewall
or put tubes in them
EDIT
sorry you said no full slicks
Re: Slicks, Best brand for stability at speed [Re: MR_P_BODY] #199733
01/21/09 12:54 AM
01/21/09 12:54 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
No, Im looking for full slicks.
Re: Slicks, Best brand for stability at speed [Re: Von] #199734
01/21/09 01:02 AM
01/21/09 01:02 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Your car didnt pick up using the ET street radials? I picked up over .400 going to the street radial from the ET slick and dropped 60' time from 1.47 to 1.36....Phill
Re: Slicks, Best brand for stability at speed [Re: 9 Sec Phill] #199735
01/21/09 01:45 AM
01/21/09 01:45 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
over a tenth 60 ft. by going from slicks TO Drag Radials?!!! no other changes? Really?
Re: Slicks, Best brand for stability at speed [Re: StealthWedge67] #199736
01/21/09 02:15 AM
01/21/09 02:15 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My son and I both like the way out Hoosier QTP tires handle. They are a bias street leagal tire that is basically a slick with 2 treads on them. But I plan to try a 30 x 9 radial slick on my 63 this year as I can get a good set for FREE ! I hope to try them in late March or early April. Ron
Re: Slicks, Best brand for stability at speed [Re: 383man] #199737
01/21/09 10:19 AM
01/21/09 10:19 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Von, I like Phoenix tires.
Re: Slicks, Best brand for stability at speed [Re: Von] #199738
01/21/09 10:33 AM
01/21/09 10:33 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Actually in my experience M/T's have a stiffer sidewall than many. If you were unstable at speed I'd say that you were underinflated or undersized. Street/strip radials require some pretty specific chassis tuning to work real well. I suggest you stay away from them unless they are required to make a class. ET streets both biased and radial(see above comments) work pretty well with the biased a little more consistant and the radial a touch quicker.
Re: Slicks, Best brand for stability at speed [Re: StealthWedge67] #199739
01/21/09 10:46 AM
01/21/09 10:46 AM
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Yes, ask some guys here, most will say that the street Radials are faster then the slicks by a few tenths on a good track, my old car always hooked unless the track was way bad....Phill
Re: Slicks, Best brand for stability at speed [Re: BobR] #199740
01/21/09 10:51 AM
01/21/09 10:51 AM
Hampstead, MD.
Troublemaker427 Offline
Hampstead, MD.
If you want to run a slick go with a radial. They will be faster and more stable than a bias tire. I've run 9x30 and 10.5x30 radial slicks and they handle like a street tire. No tail wag at all. The only disadvantage is they will spin easier on a marginal track than a bias tire. They also don't recover once they break loose like a bias. Run 18+ psi in them and don't do much of a burnout. They also seem to last longer than a bias tire. They also don't grow like a bias tire which is good if your clearances are tight.
Jody Aberts 1966 Fairlane 427 Troublemaker2 AA/NSS 1964 Galaxie 500XL 390-4spd. 1966 F-100 390-C6 1967 Plymouth VIP 383-TF 2003 Roadking
Re: Slicks, Best brand for stability at speed [Re: Troublemaker427] #199741
01/21/09 11:27 AM
01/21/09 11:27 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Id like to but as I said, I cant find one short enough. I dont want to change gears just to run a radial slick.
Re: Slicks, Best brand for stability at speed [Re: 383man] #199742
01/21/09 11:30 AM
01/21/09 11:30 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Ron, I tried the QTPs when they first came out. I couldnt get a bite with them. I also didnt care for the way they handled on the street. I know alot of guys like them, but they didnt work so well for me.
Wish I could find a set of slicks for free!
Re: Slicks, Best brand for stability at speed [Re: BobR] #199743
01/21/09 11:34 AM
01/21/09 11:34 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Bob, I am using ET street radials now. On my car they are touchy to PSI, a hair too much or too little and they wont bite. When they bite, they bite good.
My best 60 is only 1.60, so I was gonna try a set of slicks and see if I can improve on that.
'Course I still only have 4.5 inches of travel in the front. Calvert is dead set you need 5 inches minimum. The car trys to transfer weight then unloads too quick. I also havent played with the bars and rear shocks enough.
Re: Slicks, Best brand for stability at speed [Re: Von] #199744
01/21/09 12:31 PM
01/21/09 12:31 PM
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Heres a pic of the cuda on MT street radials, 1.36 60' Times. This pic is almost at the 60' box and still hanging the hoops. Not bad for a street car.
Re: Slicks, Best brand for stability at speed [Re: Von] #199745
01/21/09 12:53 PM
01/21/09 12:53 PM
Locomotion Online content
Locomotion  Online Content
If you have stability problems, make sure your wheel width is wide enough. Most Stock racers use 10" rims with 9" slicks. Worn rear or front suspension components can also be a factor.
I use Hoosier lightweight radial slicks. But I usually run on pretty well prepared tracks. Hoosier does have a variety of sizes to choose from and a call to them could also be helpful.
Hoosier slick specs
Re: Slicks, Best brand for stability at speed [Re: Von] #199746
01/21/09 01:21 PM
01/21/09 01:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I like McCreary road Starts for a car that's driven on the street. They have good trad and are nice and soft. They are for dirt track cars. They might not be up to 11.3's thou, plenty for 12.0's
Re: Slicks, Best brand for stability at speed [Re: 9 Sec Phill] #199747
01/21/09 01:24 PM
01/21/09 01:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Phil, how much spray on that launch... looks good
Re: Slicks, Best brand for stability at speed [Re: Von] #199748
01/21/09 01:26 PM
01/21/09 01:26 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Have you tried ET streets biased? They may work better for you. The Calvert bars do need a full 5 or more but you may be able to bandaid with the correct tires.
Re: Slicks, Best brand for stability at speed [Re: MR_P_BODY] #199749
01/21/09 04:20 PM
01/21/09 04:20 PM
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Raff, that was with a 200 HP hit,it ran 10.30's in the pic, but found out later that the NOS line was 85% blocked off with some lint in the filter screen. Once I got that out it ran 10.teens at LVD on the same jetting.
