Page 4 of 6 1 2 3 4 5 6
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1997102
01/23/16 04:31 PM
01/23/16 04:31 PM
NC
barracuda man Offline
NC
Originally Posted By mopar dave
im trying to get a 3300# street car(with a cage) into the 9's. my pump gas 408 got me a best of 10.35@131. without a bunch more investment i decided to rebuild it with more head, cam and compression(13.3:1). i hope this works. if not i have a holley t ram thats going on with annular 1000hp's. i have fun trying to figure this stuff out and when i cant, i just ask on here.
Dave did you ever put the main stud girdle on? I'm trying to decide if i need one for the 340 stroker build. yellow
Re: how do you make 756HP with a n/a 416? [Re: barracuda man] #1997152
01/23/16 06:00 PM
01/23/16 06:00 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Yes. It is installed. I'm using a 71 360 block filled above the soft plugs and using ARP studs.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1997166
01/23/16 06:26 PM
01/23/16 06:26 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
Hmmmm 750 HP lol I wonder
Re: how do you make 756HP with a n/a 416? [Re: one bad fish] #1997194
01/23/16 07:10 PM
01/23/16 07:10 PM
Mt Morris Michigan
Mt Morris Michigan
Not sure what your referring to. My new build is on the stand waiting for the Dyno and it will not make 750. I will be happy with 650.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1997241
01/23/16 08:51 PM
01/23/16 08:51 PM
bronx n.y
O
O
bronx n.y
What head did u use
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1997259
01/23/16 09:13 PM
01/23/16 09:13 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
Hi Dave, that combo has not got the 245 on it but ported over here all i know it has big cam shift 7800 14.1 comp the guy that build it has a heap of chev,fords running 8 s in full weight cars . as you know i made 800 hp with my 360 on gas 9.50 @143 at 3550 lbs race weight and i sold it a year ago ,the block was starting to give up a little .lol i brought it back last week and i will re block it and will try to make 900 hp with it lol should be fun
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1997261
01/23/16 09:16 PM
01/23/16 09:16 PM
bronx n.y
O
O
bronx n.y
What head did u make 800 with
Re: how do you make 756HP with a n/a 416? [Re: one bad fish] #1997275
01/23/16 09:32 PM
01/23/16 09:32 PM
Mt Morris Michigan
Mt Morris Michigan
I used the 360-1's fully ported to 230+cc range and max flow was 330@700 and 800. Mid lift numbers are way up as well. Dwayne welder did all the work. They look real nice. Will see how they perform.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1997279
01/23/16 09:34 PM
01/23/16 09:34 PM
bronx n.y
O
O
bronx n.y
It should make some good power I got the same heads
Re: how do you make 756HP with a n/a 416? [Re: Ian] #1997280
01/23/16 09:35 PM
01/23/16 09:35 PM
Mt Morris Michigan
Mt Morris Michigan
Impressive. Sounds like that guy really knows how to make power.
Re: how do you make 756HP with a n/a 416? [Re: one bad fish] #1997284
01/23/16 09:38 PM
01/23/16 09:38 PM
Mt Morris Michigan
Mt Morris Michigan
What are your engine HP numbers and what does your combo run? What have you done to your heads.
Re: how do you make 756HP with a n/a 416? [Re: one bad fish] #1997296
01/23/16 09:59 PM
01/23/16 09:59 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
the 230 cnc indy but on gas/nos
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1997301
01/23/16 10:02 PM
01/23/16 10:02 PM
bronx n.y
O
O
bronx n.y
My engine guy did some stuff but my car runs really well full body car no Trans break stock block.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1997302
01/23/16 10:03 PM
01/23/16 10:03 PM
bronx n.y
O
O
bronx n.y
. Press on the pic
Re: how do you make 756HP with a n/a 416? [Re: one bad fish] #1997313
01/23/16 10:17 PM
01/23/16 10:17 PM
Mt Morris Michigan
Mt Morris Michigan
Nice. Same here. Full body with caltracs rancho full interior with cage. What have you done to your suspension?
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1997325
01/23/16 10:35 PM
01/23/16 10:35 PM
bronx n.y
O
O
bronx n.y
Caltracs shocks straight up with Santuff shocks
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1997328
01/23/16 10:38 PM
01/23/16 10:38 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dave, what cam and intake are you using?
Re: how do you make 756HP with a n/a 416? [Re: justinp61] #1997340
01/23/16 10:56 PM
01/23/16 10:56 PM
Mt Morris Michigan
Mt Morris Michigan
Bullet did another regrind on it. Now its 267/275@50-.688/.688 on 106. Same ported Indy intake.
Re: how do you make 756HP with a n/a 416? [Re: one bad fish] #1997352
01/23/16 11:15 PM
01/23/16 11:15 PM
Mt Morris Michigan
Mt Morris Michigan
Dwayne welder got the exhaust flow better as well. 210 to 144@700. Smaller exhaust valve too 1.625 vs the old 1.650. The whole package should work much better.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1997356
01/23/16 11:20 PM
01/23/16 11:20 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Our builds are similar, heads and intake are the same. I'm only 11.2-1 though. my cam is 263/271 @ .050., .741/.738", 4.09" bore and 4.125" stroke for 434". Mine should be finished and on the dyno next month. I'm not planning on posting any numbers though, to many arm chair experts.
