Re: how do you make 756HP with a n/a 416?
[Re: mopar dave]
#1995491
01/21/16 01:29 PM
01/21/16 01:29 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I know of a W9 340 combo that made 696? So just add cubes, easy right? lol
68 Barracuda Formula S 340
[Re: mopar dave]
#1995537
01/21/16 03:19 PM
01/21/16 03:19 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Man I wish we could just race dynos instead of wasting our time going to the track. Not happy with the numbers change the correction numbers. Lol. So many of these builds are disappointing once they hit the track
[Re: pittsburghracer]
#1995555
01/21/16 03:49 PM
01/21/16 03:49 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Man I wish we could just race dynos instead of wasting our time going to the track. Not happy with the numbers change the correction numbers. Lol. So many of these builds are disappointing once they hit the track Not speaking of the engine build in question here in particular, but a LOT of them I've seen never amount to much at the track.
#1995568
01/21/16 03:57 PM
01/21/16 03:57 PM
Posts: 760 Canada
CTD5.9
Canada
Man I wish we could just race dynos instead of wasting our time going to the track. Not happy with the numbers change the correction numbers. Lol. So many of these builds are disappointing once they hit the track Should it be installed in a 1977 royal monaco with 2.73 gears and a stock converter, mismatched 15 year old uniroyal tires and original shocks then taken down the track so you can get its real horsepower? So many builds are put into disappointing cars if only there was some sort of tool to test it prior to installing it.
[Re: mopar dave]
#1995581
01/21/16 04:08 PM
01/21/16 04:08 PM
Posts: 1,632 Lubbock,TX
DavidDean
Lubbock,TX
My 454 indy headed SB made 778 @ 6500. It has a very mild roller,X block. Its been 5.66 @ 120 in my 2850# Duster. Its also broken its share of 904 parts and 8 3/4" rears. Now it has a dana.
[Re: mopar dave]
#1995596
01/21/16 04:33 PM
01/21/16 04:33 PM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
iv seen some chassis pics of the other side of steves car. nothing expensive under there. i have way more invested in my chassis and cant get out of the 10's. motor and trans is his biggest expense. like i said before chassis engineering shocks on each corner. im just amazed at how well the car works with what he has there. again, any ideas at to what you think might be in that 416 combo? https://www.youtube.com/watch?v=UDBkXRiDkxU
#1995604
01/21/16 04:46 PM
01/21/16 04:46 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Man I wish we could just race dynos instead of wasting our time going to the track. Not happy with the numbers change the correction numbers. Lol. So many of these builds are disappointing once they hit the track 😂😂😂😂😂😂
[Re: mopar dave]
#1995606
01/21/16 04:48 PM
01/21/16 04:48 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Well I see a vacuum pump so I'm betting a custom piston and ring package, at that compression VERY expensive gasoline, betting on a bigger than stock intake valve and heavily ported heads and intake, roller cams a big help, and it sound like a well built standard transmission. Just my thoughts.
[Re: mopar dave]
#1995617
01/21/16 05:05 PM
01/21/16 05:05 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
the car runs low 9's in a duster with ladder bars and comp engineering shocks. nothing fansy here. it has been in the 8's as well. maybe that puts things into perspective here. seems like his et would be better than low 9's w/ 756hp. unless he has a ton of mph?????
[Re: mopar dave]
#1995634
01/21/16 05:27 PM
01/21/16 05:27 PM
an8sec70cuda
Justinp61...Pittsburghracer was just trying to help figure out what this combo consisted of, which the OP was asking about in his first post. I agree that this particular combo seems to run good. Love the Lenco!
