Page 1 of 6 1 2 3 4 5 6
how do you make 756HP with a n/a 416? #1995465
01/21/16 12:53 PM
01/21/16 12:53 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
steve clukeys engine is one bad ass small block. what do you think it would take for heads, cam and compression to make this kind of power? I'm thinking hes using the 245cc heads on this as the peak torque is way high at 6100rpm.
https://www.youtube.com/watch?v=5vMv5zjW9oI
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995482
01/21/16 01:18 PM
01/21/16 01:18 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
how? NASCAR type money, that's how.
Coming soon!!!!
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995491
01/21/16 01:29 PM
01/21/16 01:29 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I know of a W9 340 combo that made 696? So just add cubes, easy right? lol
68 Barracuda Formula S 340
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995504
01/21/16 02:18 PM
01/21/16 02:18 PM
Renton Washington
Triple Threat Offline
Renton Washington
1.82 per cube. Definitely doable.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995506
01/21/16 02:24 PM
01/21/16 02:24 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Lots of $$$ grin
72 Plymouth Roadrunner 11.08@123.25
Re: how do you make 756HP with a n/a 416? [Re: Roughbird72] #1995514
01/21/16 02:40 PM
01/21/16 02:40 PM
Mt Morris Michigan
Mt Morris Michigan
this is with indy heads. im thinking he may have $15,000-20,000 in it. how do you do it with indy heads not W heads? if it has 14:1 compression, .700" cam and 245cc heads would this be enough to make 750ish? hp peaked at 7000@756
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995537
01/21/16 03:19 PM
01/21/16 03:19 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Man I wish we could just race dynos instead of wasting our time going to the track. Not happy with the numbers change the correction numbers. Lol. So many of these builds are disappointing once they hit the track
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: how do you make 756HP with a n/a 416? [Re: pittsburghracer] #1995545
01/21/16 03:38 PM
01/21/16 03:38 PM
Mt Morris Michigan
Mt Morris Michigan
the car runs low 9's in a duster with ladder bars and comp engineering shocks. nothing fansy here. it has been in the 8's as well. maybe that puts things into perspective here.
Re: how do you make 756HP with a n/a 416? [Re: pittsburghracer] #1995555
01/21/16 03:49 PM
01/21/16 03:49 PM
an8sec70cuda Offline
iagree iagree iagree Not speaking of the engine build in question here in particular, but a LOT of them I've seen never amount to much at the track.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: how do you make 756HP with a n/a 416? [Re: pittsburghracer] #1995568
01/21/16 03:57 PM
01/21/16 03:57 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Should it be installed in a 1977 royal monaco with 2.73 gears and a stock converter, mismatched 15 year old uniroyal tires and original shocks then taken down the track so you can get its real horsepower?
So many builds are put into disappointing cars if only there was some sort of tool to test it prior to installing it.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995581
01/21/16 04:08 PM
01/21/16 04:08 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
My 454 indy headed SB made 778 @ 6500. It has a very mild roller,X block. Its been 5.66 @ 120 in my 2850# Duster. Its also broken its share of 904 parts and 8 3/4" rears. Now it has a dana.
Re: how do you make 756HP with a n/a 416? [Re: DavidDean] #1995594
01/21/16 04:26 PM
01/21/16 04:26 PM
Mt Morris Michigan
Mt Morris Michigan
sounds like a real nice combo you have.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995596
01/21/16 04:33 PM
01/21/16 04:33 PM
Mt Morris Michigan
Mt Morris Michigan
iv seen some chassis pics of the other side of steves car. nothing expensive under there. i have way more invested in my chassis and cant get out of the 10's. motor and trans is his biggest expense. like i said before chassis engineering shocks on each corner. im just amazed at how well the car works with what he has there.
again, any ideas at to what you think might be in that 416 combo?
https://www.youtube.com/watch?v=UDBkXRiDkxU
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995599
01/21/16 04:37 PM
01/21/16 04:37 PM
Mt Morris Michigan
Mt Morris Michigan
heres another https://www.youtube.com/watch?v=HTybSlxVelM
alot of guys on here talk about how important good shocks are as well as chassis set up. steve has none of that and the car runs fansastic every run.
Re: how do you make 756HP with a n/a 416? [Re: pittsburghracer] #1995604
01/21/16 04:46 PM
01/21/16 04:46 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995606
01/21/16 04:48 PM
01/21/16 04:48 PM
PA.
"Little"John
"Little"John
PA.
Well I see a vacuum pump so I'm betting a custom piston and ring package, at that compression VERY expensive gasoline, betting on a bigger than stock intake valve and heavily ported heads and intake, roller cams a big help, and it sound like a well built standard transmission. Just my thoughts.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995617
01/21/16 05:05 PM
01/21/16 05:05 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
seems like his et would be better than low 9's w/ 756hp. unless he has a ton of mph?????
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995630
01/21/16 05:24 PM
01/21/16 05:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
9.09 @ 145, looks to me like it's smoking' right along.
What's stock valves or ported heads have to do with anything? Is there a "cheap" race gas? Tons of street cars have ported heads. Hell my new street/strip build has custom pistons and ported heads, intake too. Oh yeah, roller cam too. laugh2
Re: how do you make 756HP with a n/a 416? [Re: mopar dave] #1995634
01/21/16 05:27 PM
01/21/16 05:27 PM
Justinp61...Pittsburghracer was just trying to help figure out what this combo consisted of, which the OP was asking about in his first post.
I agree that this particular combo seems to run good. Love the Lenco!
CHIP
Re: how do you make 756HP with a n/a 416? [Re: an8sec70cuda] #1995639
01/21/16 05:34 PM
01/21/16 05:34 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
