Re: how do you make 756HP with a n/a 416?
[Re: PETE@BESTMACHINE]
#1996252
01/22/16 01:17 PM
01/22/16 01:17 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Dave you make it sound like its hard to do. The Indy head makes good power and with proper machine work and a solid combination you are there. https://www.facebook.com/media/set/?set=a.605850896137264.1073741836.135175363204822&type=3This engine did cost appox 24,000 that included the new R3 block and a Callies crank, Compstar rods, CP pistons And T&D rockers. We used his 4150 carb and Vac pump. VP C-12 fuel was used and the heads were CNC ported at Indy and no other work was done to them. Why did you go with a 59 degree motor
[Re: SpareParts]
#1996412
01/22/16 05:17 PM
01/22/16 05:17 PM
Posts: 4,457 Washington
madscientist
Washington
The odds of getting into territory the 59* can't handle with an indy 245 is SLIMMMM
Nobody remembers the old 59* W9 stock suspension dart with one kit that was running 5.1X 10 years ago with big wheel stands killing some ET!? That car proved to me that 90% of us would be totally fine with 59* blocks.
Shame nobody else noticed I failed to mention that issue with the "X" and "R1" and evidently some of the "R3's" could be had with 59* LBA's. I had forgotten about the "R3's". The real issue with the 59* LBA is net valve lift and RPM potential. I ran my 59* stuff to 8500 plus but it was nightmare. And I always felt I could use way more lift that I was using (net .750). As far as durability the blocks are pretty much the same.
[Re: SpareParts]
#1996757
01/23/16 01:07 AM
01/23/16 01:07 AM
Posts: 20,200 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Small blocks are fun but it's so much cheaper, dependable, and longer lasting to run 8's with a big block
[Re: mopar dave]
#1996872
01/23/16 10:21 AM
01/23/16 10:21 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
this one is on the money ,std 360 block asp 408 small block and 727 trans $25,000 — Gold Coast, Queensland Small block,indy 360-1 heads and manifold Complete sump to carby Afd 950 carby,electric waterpump,vacumm pump,msd 7 digital,crank trigger Msd starter motor,pipes Advanced engines built march 2015 Protrans built 727 with proflite internals Grinner reverse pattern transbrake valve body A1 converter Best 9.33 @144mph in 3150lb car 1.30 6o foot,5.9 @115 half track
[Re: madscientist]
#1996888
01/23/16 11:17 AM
01/23/16 11:17 AM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
The real issue with the 59* LBA is net valve lift and RPM potential. I ran my 59* stuff to 8500 plus but it was nightmare. What was nightmare about it?
[Re: pittsburghracer]
#1996974
01/23/16 01:48 PM
01/23/16 01:48 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
I agree but a bb should run them numbers without blinking an eye...and imo it's not a challenge. I have friends with stock block sb chevys in the 7 sec zone...Yes Stock block 23* and to me it's different and exciting response to Pittsburghs post.
[Re: fishy340]
#1996993
01/23/16 02:07 PM
01/23/16 02:07 PM
Posts: 20,200 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I agree but a bb should run them numbers without blinking an eye...and imo it's not a challenge. I have friends with stock block sb chevys in the 7 sec zone...Yes Stock block 23* and to me it's different and exciting response to Pittsburghs post. Oh don't get me wrong, I like a good challenge but I also like doing it on a budget. My stock block 360 with edelbrock heads will probably be in the 9.50's (@ 2800 pounds) this year with nothing fancy in it. But my 512 will be in the 8's at 2800 pounds and I only have about 7500-8000 dollars invested including my mega block
