Re: how do you make 756HP with a n/a 416?
[Re: an8sec70cuda]
#1995641
01/21/16 05:36 PM
01/21/16 05:36 PM
dartman366
Mt. Vernon, Ohio
Justinp61...Pittsburghracer was just trying to help figure out what this combo consisted of, which the OP was asking about in his first post. I agree that this particular combo seems to run good. Love the Lenco! Look's to me like the guy has the "Package" pretty well scienced out.
[Re: mopar dave]
#1995683
01/21/16 06:27 PM
01/21/16 06:27 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Yes its a very nice combo and runs great. Just trying to point out that its not a cheap build or probably one that I would pick for a weekly bracket raced program. If it truly weights in the 2800 pound area that makes it even more impressive.
[Re: mopar dave]
#1995838
01/21/16 09:25 PM
01/21/16 09:25 PM
Posts: 4,457 Washington
madscientist
Washington
Also,if you look at the engine pics you'll see Harland sharp rockers,not t&d or jessel and some of the Carbs had press in air bleeds and the block is an X block,not an r3 or some other high dollar race block like some on here say you must have to live. This engine sees 8000rpm regularly. What kind of compression do you think it would take to make 750 with this combo? There is so little difference between the "X" blocks and the "R" blocks it is of little consequence (not including deck heights and over bore potential).
[Re: mopar dave]
#1995899
01/21/16 10:30 PM
01/21/16 10:30 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
My old 422 w5 got upgraded and ended up making about 707 horsepower. I would think with a bigger head a true 750 would be easily possible. Best Machine dyno'ed the W5 and it ended up running 140mph in a 3220 pound Super stock spring car with a 727. So the numbers definitely line up. That's 14 to 1, gas ported slugs, 043 ring pack, and very good attention to detail in the machine work. Nice heathy roller.
[Re: mopar dave]
#1995932
01/21/16 10:51 PM
01/21/16 10:51 PM
madscientist
Washington
No kidding? I could of bought a X block 5 yrs ago for $1000. Guess I should of bought it. I have heard the bores are thin thou. I just bought one for the smokin price of $800.00 I'd buy every one I can. BTW I have sonic'd 5 different "X" blocks (including the one I have now) and all would go 4.100 easy. This one will go 4.125 max. I don't know where Chrysler got the 4.03 bore max.
[Re: fishy340]
#1996216
01/22/16 12:30 PM
01/22/16 12:30 PM
dartman366
Mt. Vernon, Ohio
People often say it don't run what the #s on the dyno say...Well how many have great working cars ? Half of the mopar guys won't send a converter out or invest in proper shocks..Not The motors fault imo. My car had freakin tti headers,3.91 gears,and a 5000 stall which IS FAR FROM OPTIMAL FOR A RACE CAR because I drove it on the street. that's the reason for my comment about the "package",,it's not just the motor that does the work.
