setting valve spring height
#1995598
01/21/16 04:37 PM
01/21/16 04:37 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
when setting spring height on Edelbrock Performer RPM head for a big block, the set height is 1.800 . Is there a + - tolerance ?
Re: setting valve spring height
[Re: dvw]
#1995656
01/21/16 05:55 PM
01/21/16 05:55 PM
Thumperdart
State of confusion
That`s what we did on mine.............
[Re: rowin4]
#1995720
01/21/16 07:01 PM
01/21/16 07:01 PM
Posts: 4,457 Washington
madscientist
Washington
And just as important is stem height.
[Re: rowin4]
#1995744
01/21/16 07:30 PM
01/21/16 07:30 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I just shimmed a set of springs last weekend and I was able to get them all within +/-.010". Having a set of .060", .030", and .015" shims handy sure helped.
Before I started, I searched the internet and found some company's/people suggesting +/-.020" all the way down to +/-.005" on the installed height.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: rowin4]
#1995836
01/21/16 09:22 PM
01/21/16 09:22 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#1996043
01/22/16 01:18 AM
01/22/16 01:18 AM
rowin4
Jeff at Modern Cylinder Head set them up before he passed. There 1.5 dia. triple springs, don't know why he went that way on a solid lifter cam and I didn't get the info of the manufacture of the spring set so I don't know what the spec.'s should be. I don't have a spring pressure checker but from just going through a rough set up on one head I was getting around -.005 to a +.003 so I guess that's close enough. I'll check for coil bind also.
[Re: rowin4]
#1996078
01/22/16 02:13 AM
01/22/16 02:13 AM
Cab_Burge
Those springs are probally a double spring with a flat dampener in between the inner and outer valve springs I'm sure Jeff set them up correclty for your cam type and lift, if you furnish him that information Due to the differences in rocker arm and the ratio errors try and check for coil bind at max lift below the retainers on all the valve springs, all 16 of them I like to see minimum of .060 between the coils they will vary, I've seen some that had .060 in some places and .030 to .090 in other places on the same set
[Re: Cab_Burge]
#1996101
01/22/16 03:07 AM
01/22/16 03:07 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I generally get them as close as I can. But on most heads if you want them right on you can set them on the high side and then machine the difference of the spring seat as long as its a very small amount. Ron
[Re: rowin4]
#1996996
01/23/16 02:09 PM
01/23/16 02:09 PM
Posts: 16,928 NC
440Jim
NC
Jeff at Modern Cylinder Head set them up before he passed. There 1.5 dia. triple springs, don't know why he went that way on a solid lifter cam and I didn't get the info of the manufacture of the spring set so I don't know what the spec.'s should be. I suggest getting all your springs tested so you have some idea what Jeff set them up to be. When it comes time to buy new springs, you will then have some idea. Too bad you did not get the spring part number(s).
[Re: Cab_Burge]
#1996999
01/23/16 02:11 PM
01/23/16 02:11 PM
Posts: 16,928 NC
440Jim
NC
Those springs are probally a double spring with a flat dampener in between the inner and outer valve springs Good thought! A double spring with a damper.
[Re: rowin4]
#1997304
01/23/16 10:07 PM
01/23/16 10:07 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
.100" from coil bind is a good number to set your installed height at..... ( valve lift + spring coil bind =.... )- installed height= number from coil bind.....shim accordingly
[Re: boatracer572]
#1997315
01/23/16 10:18 PM
01/23/16 10:18 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I surely hope guys aren't going by the manufactures advertised spring height installed and advertised pressures. Each and every height should be measured and the springs set up on a calibrated spring pressure checker
