setting valve spring height #1995598
01/21/16 04:37 PM
01/21/16 04:37 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
when setting spring height on Edelbrock Performer RPM head for a big block, the set height is 1.800 . Is there a + - tolerance ?
Re: setting valve spring height [Re: rowin4] #1995629
01/21/16 05:23 PM
01/21/16 05:23 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Normally you just get it as close as you can given the shims are in .015" increments.
2011 Drag Pak Challenger
Re: setting valve spring height [Re: rickseeman] #1995636
01/21/16 05:30 PM
01/21/16 05:30 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I set them +/- .005". Example; 1.785" gets .015" shim for 1.800". 1.790" gets .015" shim for 1.805". 1.800" gets no shim.you can mix and match .015",.030", .060" to get your desired heights.
Doug
Re: setting valve spring height [Re: dvw] #1995656
01/21/16 05:55 PM
01/21/16 05:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s what we did on mine.............
Re: setting valve spring height [Re: rowin4] #1995720
01/21/16 07:01 PM
01/21/16 07:01 PM
Washington
madscientist Offline
Washington
And just as important is stem height.
Re: setting valve spring height [Re: rowin4] #1995744
01/21/16 07:30 PM
01/21/16 07:30 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I just shimmed a set of springs last weekend and I was able to get them all within +/-.010". Having a set of .060", .030", and .015" shims handy sure helped.
Before I started, I searched the internet and found some company's/people suggesting +/-.020" all the way down to +/-.005" on the installed height.
Re: setting valve spring height [Re: rowin4] #1995836
01/21/16 09:22 PM
01/21/16 09:22 PM
Your way better off to buy a valve spring pressure gauge, even a cheap one thumbs and then set pressures on the seats + or - 5 lbs and check open pressures as well and check for coil bind.
On a single spring with no inner spring like the ones used on most Eddy heads you can't swap the inner around to try and balance both the seat and open pressure but knowing there all within 5 lbs on the seats is a good start thumbs twocents
On a stock type street flat tappet cam, solid or hydrauli lifters, I shoot for between 130 to 160 lbs on the seats and 325 to 350 lbs opened thumbs scope
I've seen springs that needed .060 shim to get them within 5 lbs of the others on the seats shock shruggy
I would go through all of them first to check the pressures at the same installed hieght and see which ones are the strongest ones and use them on the heavier intake valves and try and shim the rest of them to get all of them as close as you can to the strongest ones without them getting closer than .060 from coil bind thumbstwocents scope
Re: setting valve spring height [Re: Cab_Burge] #1996043
01/22/16 01:18 AM
01/22/16 01:18 AM
rowin4 Offline OP
rowin4  Offline OP
Jeff at Modern Cylinder Head set them up before he passed. There 1.5 dia. triple springs, don't know why he went that way on a solid lifter cam and I didn't get the info of the manufacture of the spring set so I don't know what the spec.'s should be. I don't have a spring pressure checker but from just going through a rough set up on one head I was getting around -.005 to a +.003 so I guess that's close enough. I'll check for coil bind also.
Re: setting valve spring height [Re: rowin4] #1996078
01/22/16 02:13 AM
01/22/16 02:13 AM
Those springs are probally a double spring with a flat dampener in between the inner and outer valve springs scope I'm sure Jeff set them up correclty for your cam type and lift, if you furnish him that information thumbs
Due to the differences in rocker arm and the ratio errors try and check for coil bind at max lift below the retainers on all the valve springs, all 16 of them scope thumbs twocents I like to see minimum of .060 between the coils thumbs they will vary, I've seen some that had .060 in some places and .030 to .090 in other places on the same set shruggy
Re: setting valve spring height [Re: Cab_Burge] #1996101
01/22/16 03:07 AM
01/22/16 03:07 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I generally get them as close as I can. But on most heads if you want them right on you can set them on the high side and then machine the difference of the spring seat as long as its a very small amount. Ron
Re: setting valve spring height [Re: rowin4] #1996996
01/23/16 02:09 PM
01/23/16 02:09 PM
NC
440Jim Offline
440Jim  Offline
NC
I suggest getting all your springs tested so you have some idea what Jeff set them up to be. When it comes time to buy new springs, you will then have some idea. Too bad you did not get the spring part number(s).
Re: setting valve spring height [Re: Cab_Burge] #1996999
01/23/16 02:11 PM
01/23/16 02:11 PM
NC
440Jim Offline
440Jim  Offline
NC
Good thought!
A double spring with a damper.
Re: setting valve spring height [Re: rowin4] #1997257
01/23/16 09:12 PM
01/23/16 09:12 PM
Jerry Kathe Offline
Jerry Kathe  Offline
They don't have to be perfect. Even with some of the highest quality springs out there the seat pressure can be +/- 20 or 30 lbs at exactly the same checking height.
Use a number that will put you close to the same seat pressure through out. The rate should keep it very close to the same on the nose, but check to be sure.
BTW....I would look deeper into the triple application for a flat tappet, whiles its possible to be the perfect spring, its a little iffy.....
Re: setting valve spring height [Re: rowin4] #1997304
01/23/16 10:07 PM
01/23/16 10:07 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
.100" from coil bind is a good number to set your installed height at.....
( valve lift + spring coil bind =.... )- installed height= number from coil bind.....shim accordingly
Re: setting valve spring height [Re: boatracer572] #1997315
01/23/16 10:18 PM
01/23/16 10:18 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I surely hope guys aren't going by the manufactures advertised spring height installed and advertised pressures. Each and every height should be measured and the springs set up on a calibrated spring pressure checker
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
