Milodon ss sb pan drag link mod help #1995307
01/21/16 01:54 AM
01/21/16 01:54 AM
CA.
RAY1969CARS Offline OP
CA.
Hi does anybody have any pictures of what they've done to the drag link or let me know in detail what I need to do on a abody
Re: Milodon ss sb pan drag link mod help [Re: RAY1969CARS] #1995319
01/21/16 02:08 AM
01/21/16 02:08 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You install the engine then install the drag link through the hole in the pan !!!
Re: Milodon ss sb pan drag link mod help [Re: Stanton] #1995325
01/21/16 02:12 AM
01/21/16 02:12 AM
CA.
CA.
Oh funny
Re: Milodon ss sb pan drag link mod help [Re: RAY1969CARS] #1995359
01/21/16 03:24 AM
01/21/16 03:24 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Nothing but install it. On a 70 Duster, it fit as is.
Re: Milodon ss sb pan drag link mod help [Re: RAY1969CARS] #1995430
01/21/16 11:07 AM
01/21/16 11:07 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
It wasn't remotely close to fitting with my 318 in my 71 Duster. It would pass through obviously, but wouldn't come close to bolting up.
The drag link needs to be " straightened" for it to fit, and stay the same length as stock, obviously.
I am currently out of the country in the Maldives, but I had a certified welder who is a friend of mine " fix it", turned out perfectly and works great since he did it two years ago, including at the track.
If you like you can PM me, he would probably do yours if you like.... 60 or 70 bucks, you would just have to ship it to Michigan to get it done.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Milodon ss sb pan drag link mod help [Re: RAY1969CARS] #1995451
01/21/16 12:13 PM
01/21/16 12:13 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Supposedly one from a slant six car is more straight. My dad is on here (340Cuda) and he runs these pans so maybe he will see this and chime in.
68 Barracuda Formula S 340
Re: Milodon ss sb pan drag link mod help [Re: Bad340fish] #1995459
01/21/16 12:39 PM
01/21/16 12:39 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Weld a straight piece across, then cut off the drop. Get plenty of penetration, it will be fine.
Re: Milodon ss sb pan drag link mod help [Re: RAY1969CARS] #1995478
01/21/16 01:17 PM
01/21/16 01:17 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Is the center link upside down????
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Milodon ss sb pan drag link mod help [Re: RAY1969CARS] #1995483
01/21/16 01:18 PM
01/21/16 01:18 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
When I bought my pan used I got an aftermarket bar that went through the pan. I'll post a picture of it when I get home later. matt
[img] [/img]
Re: Milodon ss sb pan drag link mod help [Re: Bad340fish] #1995524
01/21/16 02:55 PM
01/21/16 02:55 PM
cudadoug Offline
cudadoug  Offline
Ahhhhh, maybe that's why mine fit. It was a OE slant 6 car.
On a related note: The best thing we ever did with that same Milodon pan was get rid of it! Car had the ride height of a John Deere tractor for ground clearance.
Re: Milodon ss sb pan drag link mod help [Re: RAY1969CARS] #1995735
01/21/16 07:20 PM
01/21/16 07:20 PM
Washington
madscientist Offline
Washington
That Milodon pan was either the best HP pan or was within a couple of HP of every pan I've tested. That included a couple of box pans with kickouts and all the whiz bang crap. The really sad thing is that Milodon SS pan was better at the track than every other pan I tried. Better oil pressure at the leave, better oil pressure in high gear and better in the shut down. The wet sump, box style pans were hoorible. I spent more time modifying them that they were worth.
So my DD is getting the SS pan.
Re: Milodon ss sb pan drag link mod help [Re: Bad340fish] #1995821
01/21/16 08:52 PM
01/21/16 08:52 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Yes, at least on our car (69 Cuda small block) it has to be a V-8 center link also install the right direction. Don't ask me how I know.
Bill
Re: Milodon ss sb pan drag link mod help [Re: RAY1969CARS] #1996537
01/22/16 08:15 PM
01/22/16 08:15 PM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
Take your existing centerlink, weld up the large tapers a little to come close to the small diameter taper opening. Ream the new taper from the opposite direction with a 7* reamer until the tie rod stud engagement depth is equal to OE. Repeat for all 4 openings. Flip the centerlink over and install. Works great!
Brett Miller 447 W9
