Milodon ss sb pan drag link mod help
#1995307
01/21/16 01:54 AM
01/21/16 01:54 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
Hi does anybody have any pictures of what they've done to the drag link or let me know in detail what I need to do on a abody
Re: Milodon ss sb pan drag link mod help
[Re: Stanton]
#1995325
01/21/16 02:12 AM
01/21/16 02:12 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
You install the engine then install the drag link through the hole in the pan !!! Oh funny
[Re: RAY1969CARS]
#1995430
01/21/16 11:07 AM
01/21/16 11:07 AM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
It wasn't remotely close to fitting with my 318 in my 71 Duster. It would pass through obviously, but wouldn't come close to bolting up. The drag link needs to be " straightened" for it to fit, and stay the same length as stock, obviously. I am currently out of the country in the Maldives, but I had a certified welder who is a friend of mine " fix it", turned out perfectly and works great since he did it two years ago, including at the track. If you like you can PM me, he would probably do yours if you like.... 60 or 70 bucks, you would just have to ship it to Michigan to get it done.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: RAY1969CARS]
#1995451
01/21/16 12:13 PM
01/21/16 12:13 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Supposedly one from a slant six car is more straight. My dad is on here (340Cuda) and he runs these pans so maybe he will see this and chime in.
68 Barracuda Formula S 340
[Re: RAY1969CARS]
#1995483
01/21/16 01:18 PM
01/21/16 01:18 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Hi does anybody have any pictures of what they've done to the drag link or let me know in detail what I need to do on a abody When I bought my pan used I got an aftermarket bar that went through the pan. I'll post a picture of it when I get home later. matt
[img] [/img]
[Re: Bad340fish]
#1995524
01/21/16 02:55 PM
01/21/16 02:55 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Supposedly one from a slant six car is more straight. My dad is on here (340Cuda) and he runs these pans so maybe he will see this and chime in. Ahhhhh, maybe that's why mine fit. It was a OE slant 6 car. On a related note: The best thing we ever did with that same Milodon pan was get rid of it! Car had the ride height of a John Deere tractor for ground clearance.
[Re: RAY1969CARS]
#1995735
01/21/16 07:20 PM
01/21/16 07:20 PM
Posts: 4,457 Washington
madscientist
Washington
That Milodon pan was either the best HP pan or was within a couple of HP of every pan I've tested. That included a couple of box pans with kickouts and all the whiz bang crap. The really sad thing is that Milodon SS pan was better at the track than every other pan I tried. Better oil pressure at the leave, better oil pressure in high gear and better in the shut down. The wet sump, box style pans were hoorible. I spent more time modifying them that they were worth.
So my DD is getting the SS pan.
[Re: Bad340fish]
#1995821
01/21/16 08:52 PM
01/21/16 08:52 PM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Supposedly one from a slant six car is more straight. My dad is on here (340Cuda) and he runs these pans so maybe he will see this and chime in. Yes, at least on our car (69 Cuda small block) it has to be a V-8 center link also install the right direction. Don't ask me how I know. Bill
[Re: RAY1969CARS]
#1996537
01/22/16 08:15 PM
01/22/16 08:15 PM
Posts: 89 Woodbury, CT.
mcduff
Woodbury, CT.
Take your existing centerlink, weld up the large tapers a little to come close to the small diameter taper opening. Ream the new taper from the opposite direction with a 7* reamer until the tie rod stud engagement depth is equal to OE. Repeat for all 4 openings. Flip the centerlink over and install. Works great!
Brett Miller 447 W9
