Safety Question: Do you use a HANS type device? #1978611
12/29/15 03:21 PM
12/29/15 03:21 PM
Richmond, Tx. (Houston)
GTSDave Offline OP
GTSDave  Offline OP
If so which one, and if you had to buy one today would you go with the same one you have now?
I am shopping for one and have no idea which one to go with. There are so many choices....
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Safety Question: Do you use a HANS type device? [Re: GTSDave] #1978808
12/29/15 07:51 PM
12/29/15 07:51 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I do and would but there are other choices that some people like better. Whatever you do, get the quick release system.
Re: Safety Question: Do you use a HANS type device? [Re: GTSDave] #1993393
01/18/16 04:01 PM
01/18/16 04:01 PM
GTSDave Offline OP
GTSDave  Offline OP
Thanks,
Still looking at several different ones. Seems that are lots of choices, and some look like they would be more comfortable than others. Problem is they don't carry them locally so it is hard to try one on to see how it feels. Some look like a medieval torture device! Wonder which ones provide the best comfort V/S safety......
-Dave
Re: Safety Question: Do you use a HANS type device? [Re: GTSDave] #1993544
01/18/16 08:28 PM
01/18/16 08:28 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
I decided to go with the Necksgen. http://www.necksgen.com/
It is easy to get in and out of by myself and allows some side to side movement. My car is not that fast, but I'm fragile.... so felt I wanted something.
Re: Safety Question: Do you use a HANS type device? [Re: GTSDave] #1993760
01/19/16 12:00 AM
01/19/16 12:00 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Another vote for Necksgen here. IMO more comfortable and more movement.
Re: Safety Question: Do you use a HANS type device? [Re: GTSDave] #1994049
01/19/16 01:44 PM
01/19/16 01:44 PM
GTSDave Offline OP
GTSDave  Offline OP
The Necksgen seems to be the most popular right now. Saw a couple of videos online though that has me a little weary.
Necksgen
https://www.youtube.com/watch?v=RFlmJHP2o90
HANS
https://www.youtube.com/watch?v=SDuRVC1HJfs
I am still leaning towards the necksgen, but the HANS sure looks like it gives better protection.
Re: Safety Question: Do you use a HANS type device? [Re: GTSDave] #1994219
01/19/16 05:53 PM
01/19/16 05:53 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Sure looks like you still get a lot of head movement with the necksgen.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Safety Question: Do you use a HANS type device? [Re: 1967dartgt] #1994357
01/19/16 09:29 PM
01/19/16 09:29 PM
Marysville Wa
moparfan Offline
moparfan  Offline
Marysville Wa
I've worn a Hans for the last 2 years. You can turn your head 90 degrees with the sliding tethers. If your the slow car w/o mirrors it will be an issue. Other than that I can't tell it's on. I put it on in the car and take it off in the car before I get out after the run.
Only issue I had is when I first starting wearing it was I would over tighten the belts. I was used to pulling the belts tighter as I pulled into the water box. With the Hans under the belts its hard to feel how tight the belts are.
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: Safety Question: Do you use a HANS type device? [Re: GTSDave] #1994362
01/19/16 09:35 PM
01/19/16 09:35 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
I like the Simpson Hybrid Sport.. Easy on and off with the -15 firesuit on and has decent movement side to side when strapped in.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: Safety Question: Do you use a HANS type device? [Re: GTSDave] #1994405
01/19/16 10:23 PM
01/19/16 10:23 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Remember that there are also restraints to keep arms and legs inside the cage in a wreck, same principle, even something made from Velcro with a tether to a tab on a cage member will help.
Boffin Emeritus
Re: Safety Question: Do you use a HANS type device? [Re: GTSDave] #1994508
01/20/16 12:02 AM
01/20/16 12:02 AM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
I like the HANS unit, been using for last couple of years.. Tethers allow plenty of room for movement. I really like how device wraps around chest. Im also a guy that cranks on my belts,was always told loose is a no no
