Safety Question: Do you use a HANS type device?
#1978611
12/29/15 03:21 PM
12/29/15 03:21 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
If so which one, and if you had to buy one today would you go with the same one you have now?
I am shopping for one and have no idea which one to go with. There are so many choices....
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Safety Question: Do you use a HANS type device?
[Re: GTSDave]
#1993393
01/18/16 04:01 PM
01/18/16 04:01 PM
GTSDave
Thanks,
Still looking at several different ones. Seems that are lots of choices, and some look like they would be more comfortable than others. Problem is they don't carry them locally so it is hard to try one on to see how it feels. Some look like a medieval torture device! Wonder which ones provide the best comfort V/S safety......
-Dave
[Re: GTSDave]
#1993544
01/18/16 08:28 PM
01/18/16 08:28 PM
Posts: 570 Brea, Ca
Dart Racer
Brea, Ca
I decided to go with the Necksgen. http://www.necksgen.com/It is easy to get in and out of by myself and allows some side to side movement. My car is not that fast, but I'm fragile.... so felt I wanted something.
[Re: GTSDave]
#1993760
01/19/16 12:00 AM
01/19/16 12:00 AM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
Another vote for Necksgen here. IMO more comfortable and more movement.
[Re: GTSDave]
#1994219
01/19/16 05:53 PM
01/19/16 05:53 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Sure looks like you still get a lot of head movement with the necksgen.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1994357
01/19/16 09:29 PM
01/19/16 09:29 PM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
I've worn a Hans for the last 2 years. You can turn your head 90 degrees with the sliding tethers. If your the slow car w/o mirrors it will be an issue. Other than that I can't tell it's on. I put it on in the car and take it off in the car before I get out after the run.
Only issue I had is when I first starting wearing it was I would over tighten the belts. I was used to pulling the belts tighter as I pulled into the water box. With the Hans under the belts its hard to feel how tight the belts are.
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
[Re: GTSDave]
#1994362
01/19/16 09:35 PM
01/19/16 09:35 PM
Posts: 200 AB
Efidart
AB
I like the Simpson Hybrid Sport.. Easy on and off with the -15 firesuit on and has decent movement side to side when strapped in.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: GTSDave]
#1994405
01/19/16 10:23 PM
01/19/16 10:23 PM
Posts: 4,207 New York
polyspheric
New York
Remember that there are also restraints to keep arms and legs inside the cage in a wreck, same principle, even something made from Velcro with a tether to a tab on a cage member will help.
Boffin Emeritus
[Re: GTSDave]
#1994508
01/20/16 12:02 AM
01/20/16 12:02 AM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
I like the HANS unit, been using for last couple of years.. Tethers allow plenty of room for movement. I really like how device wraps around chest. Im also a guy that cranks on my belts,was always told loose is a no no
