Front Runner Question #1993406
01/18/16 04:37 PM
01/18/16 04:37 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
This is important to me. here is my question,
I have a set of 27.5 x 4.5 x 15 front runners on my car. I like the tires but hate the look, when I say look they are round side to side on the rim, I have them mounted to a 4.0 wide rim. I have ordered new rims that are on back order and just need to ask this before they are delivered.
In changing the rim width will that flatten out the contact patch on the road. I am sure it will.
the tire spec is
*5.0 tread width
*7.0 section width
They say this is with a 4.0 inch rim and its shows a bubble look.
If I say run a rim that matched the section width at 7.0 I am guessing the tire will most likely be flat.
is this doable??
am I not understanding something
Thoughts
Thank you
Kiddart
Re: Front Runner Question [Re: Kiddart] #1993537
01/18/16 08:16 PM
01/18/16 08:16 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I am in the same boat as you. I would expect the sides to flatten out some w/a wider rim. But this is just speculation.
The ones on my Cuda look like they belong on an old utility trailer. Looks like crap.
I will say the Moroso tires on my wagon have a flatter side wall than the Goodyears on the Cuda,
Ok
Re: Front Runner Question [Re: cudatom] #1993583
01/18/16 09:22 PM
01/18/16 09:22 PM
fresno ca
mikeysmopars Offline
fresno ca
Kina went through that as well. New M/T 3.5 with 27x4.5 Hoosiers. They do bulge a little.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Front Runner Question [Re: Kiddart] #1993700
01/18/16 11:00 PM
01/18/16 11:00 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
the tire spec is
*5.0 tread width
*7.0 section width
is this doable??
Thoughts
No that tire will look like [censored] on a 7" rim, I would say 5" max.
The round side on them is how they are, it's the drag look, wide rims on the back and pizza cutters on the front, you will loose that look going a 7" rim.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Front Runner Question [Re: Kiddart] #1993748
01/18/16 11:52 PM
01/18/16 11:52 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The round side wall is how they are constructed. What you are suggesting sounds like it would be a PITA to get air into at best and be likely be unsafe at worse. I would not get away from the manufacture's suggested rim size. Sounds like you should ditch the race tires and look for a set of DOT tires in the size and look you want.
Re: Front Runner Question [Re: ozymaxwedge] #1993757
01/18/16 11:58 PM
01/18/16 11:58 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
the tire spec is
*5.0 tread width
*7.0 section width
is this doable??
Thoughts
I agree 5" max but its funny, my tires are on a 4" rim which was what was recommended and looks like they are 8" wide at the side wall. Now the ones on my wagon also called for 4" rim but are on my old Centerline Autodrags look fine, even with a 3.5" wide rim. Just different brand of tires and how they are designed.
I'll be getting a 5" rim and will use them on the wagon. Going to try a different brand front tire for my Cuda.
Ok
Re: Front Runner Question [Re: cudatom] #1993938
01/19/16 10:31 AM
01/19/16 10:31 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
gotta go thin and in to win....
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Front Runner Question [Re: Kiddart] #1993960
01/19/16 11:29 AM
01/19/16 11:29 AM
an8sec70cuda Offline
Depends on the exact tire in question. That size tire on a 7" wide rim is gonna look like crap.
I had a set of Pro Trac front runners that looked horrible and like you describe. Big bulging round sidewall. I had em mounted, put them on the car, hated them as soon as I dropped the jack. I took em right back off and sold them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Front Runner Question [Re: an8sec70cuda] #1993965
01/19/16 11:43 AM
01/19/16 11:43 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
It will look like all the "stance" cars with skinny tires on rims that are too wide.
Stick with what the mfg suggests...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
