Page 2 of 3 1 2 3
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993368
01/18/16 03:27 PM
01/18/16 03:27 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The coyote is a nice package and with a supercharger intake head flow becomes less important for all of them. Possibly the coyote can rpm it's way past a 50 cubic inch handicap.
Getting old just means you were smarter than some and luckier than others.
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993407
01/18/16 04:41 PM
01/18/16 04:41 PM
Skypower Offline
Skypower  Offline
I don't think RPM will be a problem for the drag pack guys to keep up with, look what Barton has done with the genII Hemis they will make it happen if they need more.
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993416
01/18/16 04:56 PM
01/18/16 04:56 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I saw an in car of Barton running a Gen III out the back door @ 8900rpm.
Mopar to the bone!!!
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993452
01/18/16 05:47 PM
01/18/16 05:47 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
HP is much more closely related to CFM than it is RPM, if you don't have any air flowing in you can't burn fuel no matter the RPM. Air flow IS going to be critical as they all have to run the same blower it seems. We have a bigger engine and bigger air flow RPM will not overcome that and like has already been mentioned the gen III is no slouch in RPM anyhow. At the same weight 50 CFM and 50 CID will spank the other guys real hard. If it was same displacment to weight it may well be another story.
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993524
01/18/16 07:53 PM
01/18/16 07:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I believe the Mopar N/A combo is the best of the bunch. That being said the NMCA weight is 200 lbs less than NHRA. I doubt if a legal NHRA cars carry 200 lbs of ballast. I would bet most cars in this class will be dual purpose NHRA/NMCA. The other issue is boost vs N/A. I think the N/A cars will be at a disadvantage. It'll be interesting to see how it all shakes out.
Doug
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993525
01/18/16 07:54 PM
01/18/16 07:54 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
If you're spinning the blower faster you're moving more air no?
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993551
01/18/16 08:45 PM
01/18/16 08:45 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Not nessacarily, a SC gets to a point where it just don't really move much more air, not to mention a greater restriction means more PSI and that menas more heat and less mass flow...
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993569
01/18/16 09:06 PM
01/18/16 09:06 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Iooked it up and the top 5 liter coyote fs/xx has run a 8.50 at 161.88 mph. That is at the class legal 3575 lbs on a 9" tire. I'm antious to see what the supercharged 354 challenger drag pak will run.
Re: This should get interesting. Factory super cars. [Re: 72Swinger] #1993574
01/18/16 09:10 PM
01/18/16 09:10 PM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Originally Posted By 72Swinger
I see the Drag Packs putting such a whoopin' on the others that they will get 'factored' to death AGAIN. Barton has dyno videos of the COPO Whipple engine making 1000+hp and the 354 Whipple engine making 1136hp. Al Carps car already owns the record for the 7.0L N/A at 8.5***ET. The Gen III Hemi's are BAD little doods. Wish "Mopar" would get some blocks into the aftermarket like NOW....
David will be racing Gary Wolkwitz's blown Copo this year pretty much due to Ma Mopar not working with the Bartons at all. Mopar did show up in the winner circle after the fact to help celebrate all of David and Rays hard work..... down
David has the copo just north of 1100 hp with some small tuning changes and right now the motor is apart and will receive the "Barton rebuild"! This car will be a player wherever David chooses to race it this year...
As for the blown dragpack- it did make north of 1100hp on the dyno also, but the factory contracted an Indiana Builder to build them for the factory and lets just say theres some illegal parts for stock eliminator inside after the Bartons pulled it apart. Right now the blown dragpak is waiting on chrysler to figure out this mess and ship the legal parts. spank If you wonder why David is racing a Copo this year then ask yourself why Chrysler wouldn't have even given the Bartons, who had the fastest Challenger by far, a chance to bid on the build of either N/A or Blown Dragpak Hemis..... Very sad day for the mopar contingent fan
SS/DA 1924
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993586
01/18/16 09:26 PM
01/18/16 09:26 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
There are many variables. Sometimes when your blower limited a smaller cubic inch is superior as the boost will be higher with the smaller engine. The other thing is exhaust flow becomes very important on the boosted engine. I don't know which heads are superior in exhaust flow. Then the cars are racing on a small tire so the long flat torque curve the 4valve will produce may be an asset. Time will tell but after checking the performance of the cars running out there now I think the racing will be fast and fairly close. The ringer may be the supercharged challenger.
Re: This should get interesting. Factory super cars. [Re: SSDAcuda] #1993649
01/18/16 10:15 PM
01/18/16 10:15 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That REALLY bums me out. They really must have their heads where the sun dont shine, first they take a dump on Penske, then the Trans Am teams, then the Tudor Viper guys and the latest is AJ. All after OVER achieving with their brand, I dont get it. Its like if you win championships with a Dodge you get the ax, makes perfect sense to an FCA moron I guess.....
Re: This should get interesting. Factory super cars. [Re: 72Swinger] #1993697
01/18/16 10:55 PM
01/18/16 10:55 PM
Skypower Offline
Skypower  Offline
[quote=72Swinger]If you're spinning the blower faster you're moving more air no? [/quote
Yes
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993706
01/18/16 11:06 PM
01/18/16 11:06 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
This type of exposure makes much more sense than prostock to me. The cars look like what are driving around on the street with engines that you can get in a production car. Who would not want their Brand at the top of the heap. It's crazy.
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993744
01/18/16 11:48 PM
01/18/16 11:48 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Its corporate talking heads making decisions based on budget instead of loyalty or integrity. I hope David KILLS the 354's with his COPO, if they are that stupid, they have it coming....
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993759
01/18/16 11:58 PM
01/18/16 11:58 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
How does the head flow compare between the 3? Is the COPO using an LS3 head? Gen III a 6.2 head? Is porting allowed?
Re: This should get interesting. Factory super cars. [Re: 72Swinger] #1993933
01/19/16 10:00 AM
01/19/16 10:00 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
If it was budget, there would've been specs for a few to quote the build. This appears to be politics..... Obama style! fan down whiney
I don't know what Mopar based their decision on, but I can tell you if they wanted to win, they would've at least heard what the fastest guy out their with their product had to say....
For the record, the blown dragpak was a little over 1000hp before David started tuning
SS/DA 1924
Re: This should get interesting. Factory super cars. [Re: pittsburghracer] #1993976
01/19/16 11:53 AM
01/19/16 11:53 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Was the 426 n/a motor dead legal? Or did it have "special" parts? Is it possible that the Indiana builder has supercharged ecperience? Just wondering.
Doug
Re: This should get interesting. Factory super cars. [Re: dvw] #1993989
01/19/16 12:17 PM
01/19/16 12:17 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
Doug
Thinking I read somewhere it was BES (Bischoff) which is the builder of Rob Goss's engine and the fastest gen3 period !!
No knock on Barton but it would be silly to think he's the only one who can tune or make gen3's run !!!
Re: This should get interesting. Factory super cars. [Re: Gary Robbins] #1994206
01/19/16 05:32 PM
01/19/16 05:32 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I was just reading the rules and they stated that the automatic transmission must be the same make as the car. Someone correct me if I'm wrong but didn't the early V-10 drag pack cars have a glide in them shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: This should get interesting. Factory super cars. [Re: fourgearsavoy] #1994311
01/19/16 08:05 PM
01/19/16 08:05 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
[quote=fourgearsavoy]I was just reading the rules and they stated that the automatic transmission must be the same make as the car. Someone correct me if I'm wrong but didn't the early V-10 drag pack cars have a glide in them shruggy
Gus beer [/quote
I believe you can run a glide or a Proflite in all 3 makes.
Doug
Page 2 of 3 1 2 3
