Valve Cover Hell #1992585
01/17/16 02:33 PM
01/17/16 02:33 PM
Georgia
Matt M Offline OP
Matt M  Offline OP
Georgia
What started out as an easy fix has gone South fast on me.
Always seems the easy stuff gets side ways.
I was replacing a leaking valve cover gasket.
I snapped off a bolt......
I cut a groove in the small piece that was above the head, but the groove was not deep enough for a screw driver to get a bite.
I tried an "easy-out" drill bit.....can't get it to bite when I reverse it out.
I need some help here.
Any ideas.....
I need to get this taken care of and get rolling ....
Matt
Re: Valve Cover Hell [Re: Matt M] #1992591
01/17/16 02:39 PM
01/17/16 02:39 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
What's this on?
Sounds like you might have to drill it out and re tap
Re: Valve Cover Hell [Re: Matt M] #1992594
01/17/16 02:43 PM
01/17/16 02:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
easy out drill bit?
Not sure what that is, an easy out is a tapered left hand flute device, not a drill bit.
Some people use a left hand thread drill bit as an easy out like device though it isn't one and doesn't always work.
Try a real easy out. If you have some small square stock you can grind a taper on it and use it as a removal tool in a pinch. Sometimes you can use a torx screwdriver as a removal tool.
Don't be the exception.
Re: Valve Cover Hell [Re: Matt M] #1992600
01/17/16 02:48 PM
01/17/16 02:48 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Sometimes with stuck bolts I heat it and touch some wax to it to melt around the threads. Then usually the bolt comes out pretty easy with a reverse left handed drill bit.
Re: Valve Cover Hell [Re: Matt M] #1992609
01/17/16 02:55 PM
01/17/16 02:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If you have a welder you can weld the end of an allen wrench or something similar to it & back it out.
Re: Valve Cover Hell [Re: Alaskan_TA] #1992625
01/17/16 03:07 PM
01/17/16 03:07 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i sorta did this on a garden tractor starter bolt that snapped off. JB Weld to another bolt and 2 days of waiting...
Re: Valve Cover Hell [Re: Alaskan_TA] #1992630
01/17/16 03:11 PM
01/17/16 03:11 PM
I think he was referring to one of those drill bits that you drill it CCW with a reverseing drill & they work occaisionally on softer material but I'd say the odds ain't good here. As said I'd just drill it out (normally) & corral the shavings (greaseing the bit helps)
Re: Valve Cover Hell [Re: RapidRobert] #1992676
01/17/16 03:59 PM
01/17/16 03:59 PM
michigan
440whiteboy Offline
440whiteboy  Offline
michigan
do a google search ( picture of easy out tool )
I did this with the same problem.
I used an 1/8" drill bit -
drilling to the bottom - apx 1 1/4" max.
then I used an 3/16" -1/4" drill bit same thing.
using the easy out tool after torching to warm it up,
brought it right out.
They only see Stars...
when hit by a Mopar!
Re: Valve Cover Hell [Re: 440whiteboy] #1992982
01/17/16 10:21 PM
01/17/16 10:21 PM
Georgia
Matt M Offline OP
Matt M  Offline OP
Georgia
Thanks for all the replies
I spoke to a friend
He told me the same thing as pictured " a real bolt puller"
Hopefully I will get it out this week and be rolling in my U code Challenger.
Thanks Matt
Re: Valve Cover Hell [Re: Matt M] #1992983
01/17/16 10:23 PM
01/17/16 10:23 PM
Georgia
Matt M Offline OP
Matt M  Offline OP
Georgia
Victim
Re: Valve Cover Hell [Re: Matt M] #1992993
01/17/16 10:39 PM
01/17/16 10:39 PM
Salem, NY
69gtxvert Offline
69gtxvert  Offline
Salem, NY
I've had some success welding a nut to a broken bolt and turning it out with a normal wrench. Got to have enough to weld to though. Pretty frustrating - good luck.
Re: Valve Cover Hell [Re: Matt M] #1993672
01/18/16 10:30 PM
01/18/16 10:30 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Sharp lookin' car, Matt!
Is that B5 blue?
Re: Valve Cover Hell [Re: Ramrod39] #1993815
01/19/16 01:01 AM
01/19/16 01:01 AM
Georgia
Matt M Offline OP
Matt M  Offline OP
Georgia
Yes B5 with B5 Interior.
Re: Valve Cover Hell [Re: Matt M] #1993827
01/19/16 01:13 AM
01/19/16 01:13 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Re: Valve Cover Hell [Re: Ramrod39] #2002092
01/30/16 06:30 PM
01/30/16 06:30 PM
Georgia
Matt M Offline OP
Matt M  Offline OP
Georgia
A little update here.
Got the extractor in nice and tight.
as I attempted to reverse it out.......
SNAP, broken extractor.
Big breath, close the hood, walk in the house grab a beer.
The adventure continues.............
Re: Valve Cover Hell [Re: Matt M] #2002110
01/30/16 06:49 PM
01/30/16 06:49 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Man that thing was IN there.
Welder only option now or drill deep.
Re: Valve Cover Hell [Re: Matt M] #2002120
01/30/16 07:08 PM
01/30/16 07:08 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Beautiful Challenger!
Re: Valve Cover Hell [Re: Matt M] #2002121
01/30/16 07:10 PM
01/30/16 07:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have done that same thing in the past and that is the worse possible outcome.
My first duty station in the Navy was overhauling various antennas. I learned the hard way about broken bolts, extractors and corrosion.
They make an extractor remover, never tried one though. I usually used a punch to fracture the broken extractor, cause you ain't drilling it out. I understand that some machine shops can burn it out with a fancy machine, never used that either. But it'll cost at least a head gasket as well.
I never tried heating the broken extractor up red hot and hitting it with a freeze spray, but some have had success.
Re: Valve Cover Hell [Re: Supercuda] #2002159
01/30/16 08:09 PM
01/30/16 08:09 PM
Georgia
Matt M Offline OP
Matt M  Offline OP
Georgia
Not sure next course action.
If there is a member in Tampa FL with some experience with this
kind of issue that wants to make some $ and drink some cold beer
let me know.
I think this project may have hit terminal velocity for me....LOL
Re: Valve Cover Hell [Re: Matt M] #2002209
01/30/16 09:02 PM
01/30/16 09:02 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Whereabouts in Tampa?
