Re: Valve Cover Hell
[Re: Matt M]
#1992594
01/17/16 02:43 PM
01/17/16 02:43 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
easy out drill bit?
Not sure what that is, an easy out is a tapered left hand flute device, not a drill bit.
Some people use a left hand thread drill bit as an easy out like device though it isn't one and doesn't always work.
Try a real easy out. If you have some small square stock you can grind a taper on it and use it as a removal tool in a pinch. Sometimes you can use a torx screwdriver as a removal tool.
[Re: Alaskan_TA]
#1992625
01/17/16 03:07 PM
01/17/16 03:07 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
If you have a welder you can weld the end of an allen wrench or something similar to it & back it out. i sorta did this on a garden tractor starter bolt that snapped off. JB Weld to another bolt and 2 days of waiting...
[Re: Alaskan_TA]
#1992630
01/17/16 03:11 PM
01/17/16 03:11 PM
RapidRobert
I think he was referring to one of those drill bits that you drill it CCW with a reverseing drill & they work occaisionally on softer material but I'd say the odds ain't good here. As said I'd just drill it out (normally) & corral the shavings (greaseing the bit helps)
[Re: RapidRobert]
#1992676
01/17/16 03:59 PM
01/17/16 03:59 PM
Posts: 1,106 michigan
440whiteboy
michigan
I think he was referring to one of those drill bits that you drill it CCW with a reverseing drill & they work occaisionally on softer material but I'd say the odds ain't good here. As said I'd just drill it out (normally) & corral the shavings (greaseing the bit helps) do a google search ( picture of easy out tool ) I did this with the same problem. I used an 1/8" drill bit - drilling to the bottom - apx 1 1/4" max. then I used an 3/16" -1/4" drill bit same thing. using the easy out tool after torching to warm it up, brought it right out. -
They only see Stars... when hit by a Mopar!
[Re: 440whiteboy]
#1992982
01/17/16 10:21 PM
01/17/16 10:21 PM
Posts: 1,089 Georgia
Matt M
Georgia
I think he was referring to one of those drill bits that you drill it CCW with a reverseing drill & they work occaisionally on softer material but I'd say the odds ain't good here. As said I'd just drill it out (normally) & corral the shavings (greaseing the bit helps) do a google search ( picture of easy out tool ) I did this with the same problem. I used an 1/8" drill bit - drilling to the bottom - apx 1 1/4" max. then I used an 3/16" -1/4" drill bit same thing. using the easy out tool after torching to warm it up, brought it right out. - Thanks for all the replies I spoke to a friend He told me the same thing as pictured " a real bolt puller" Hopefully I will get it out this week and be rolling in my U code Challenger. Thanks Matt
[Re: Matt M]
#1992983
01/17/16 10:23 PM
01/17/16 10:23 PM
Matt M
Georgia
[Re: Matt M]
#2002121
01/30/16 07:10 PM
01/30/16 07:10 PM
Supercuda
About to go away
About to go away
up yours
I have done that same thing in the past and that is the worse possible outcome.
My first duty station in the Navy was overhauling various antennas. I learned the hard way about broken bolts, extractors and corrosion.
They make an extractor remover, never tried one though. I usually used a punch to fracture the broken extractor, cause you ain't drilling it out. I understand that some machine shops can burn it out with a fancy machine, never used that either. But it'll cost at least a head gasket as well.
I never tried heating the broken extractor up red hot and hitting it with a freeze spray, but some have had success.
