Originally Posted By 440whiteboy
Originally Posted By RapidRobert
I think he was referring to one of those drill bits that you drill it CCW with a reverseing drill & they work occaisionally on softer material but I'd say the odds ain't good here. As said I'd just drill it out (normally) & corral the shavings (greaseing the bit helps)
do a google search ( picture of easy out tool )
I did this with the same problem.
I used an 1/8" drill bit -
drilling to the bottom - apx 1 1/4" max.
then I used an 3/16" -1/4" drill bit same thing.
using the easy out tool after torching to warm it up,
brought it right out.
Thanks for all the replies
I spoke to a friend
He told me the same thing as pictured " a real bolt puller"
Hopefully I will get it out this week and be rolling in my U code Challenger.
Thanks Matt
