Re: This should get interesting. Factory super cars.
[Re: pittsburghracer]
#1992572
01/17/16 02:27 PM
01/17/16 02:27 PM
Posts: 5,160 Texas
dannysbee
Texas
Looking forward to it. Looks as though the Ford guys are taking it on the chin with the weight breaks. The 2.9 whipple weighs 3575 in the Chevy, Ford and Mopar camps. Chevy and Mopar are at 5.7 displacement and the ford is at 5.0. I'm thinking 4 valves will have a hard time catching 50 cubic inches.
Getting old just means you were smarter than some and luckier than others.
#1992592
01/17/16 02:39 PM
01/17/16 02:39 PM
Posts: 4,255 Canada
WO23Coronet
Canada
Index (not even sure if that's the right term) racing has always confused me. How does the current set up work where these cars race? They've never raced each other in a heads up manner before?
Extremely happy about the new class as well! Should've been done a long time ago
[Re: WO23Coronet]
#1992628
01/17/16 03:10 PM
01/17/16 03:10 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
What a great class..... wish they were running it out west as well... well maybe in the future. I would say it's going to be a difficult class to keep honest ....very difficult to police.... but I believe this is what people want to see two thumbs up for an nmca
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
#1992674
01/17/16 03:57 PM
01/17/16 03:57 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
Looks like a 425lb weight break for the N/A V-10 drag pak cars. not sure if that will be enough. When did we get a 7.0 Hemi? (Gen3, presumably) They have one listed.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
#1992794
01/17/16 05:58 PM
01/17/16 05:58 PM
Posts: 5,160 Texas
dannysbee
Texas
I believe Barton runs one of the third gens. Runs in the 8's I believe but I don't know at what weight.
#1992806
01/17/16 06:08 PM
01/17/16 06:08 PM
Posts: 4,210 New York
polyspheric
New York
Look for some "revisions" in the rules when they discover how weak the modular engine is...
Boffin Emeritus
#1992913
01/17/16 08:26 PM
01/17/16 08:26 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I see the Drag Packs putting such a whoopin' on the others that they will get 'factored' to death AGAIN. Barton has dyno videos of the COPO Whipple engine making 1000+hp and the 354 Whipple engine making 1136hp. Al Carps car already owns the record for the 7.0L N/A at 8.5***ET. The Gen III Hemi's are BAD little doods. Wish "Mopar" would get some blocks into the aftermarket like NOW....
Mopar to the bone!!!
#1992981
01/17/16 10:21 PM
01/17/16 10:21 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
This will be fun to watch!
[Re: dannysbee]
#1992994
01/17/16 10:43 PM
01/17/16 10:43 PM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Looking forward to it. Looks as though the Ford guys are taking it on the chin with the weight breaks. The 2.9 whipple weighs 3575 in the Chevy, Ford and Mopar camps. Chevy and Mopar are at 5.7 displacement and the ford is at 5.0. I'm thinking 4 valves will have a hard time catching 50 cubic inches. Those extra two valves are gold. I am betting the ferds will be VERY competitive. Don't forget that there are double overhead cams on the four valve motor. That equals faster valve action, more rpm than a pushrod motor. The GT350 motor puts out 101 hp per liter, on pump gas, in street trim. That says to me there is a lot more there in race trim, then when you put the boost to it,,,,,
#1992998
01/17/16 10:52 PM
01/17/16 10:52 PM
72Swinger
Nebraska
The Fords are bad with a blower, and no pushrods helps. I wonder if the ".675 max lift at the valve" rule is for the blower cars as well?
[Re: 72Swinger]
#1992999
01/17/16 10:55 PM
01/17/16 10:55 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am pretty sure that is the cam lift on the blown Drag Pak cars.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
#1993010
01/17/16 11:16 PM
01/17/16 11:16 PM
72Swinger
Nebraska
That must be for all of them across the board, Barton mentioned on FB that his N/A engines had that rule too.
[Re: 72Swinger]
#1993019
01/17/16 11:25 PM
01/17/16 11:25 PM
D-50
North, Alabama
That must be for all of them across the board, Barton mentioned on FB that his N/A engines had that rule too. That might have been the case instead of the blown cars.
#1993061
01/18/16 12:54 AM
01/18/16 12:54 AM
Posts: 5,160 Texas
dannysbee
Texas
Looks like Barton's fs/b track pak car ran 8.50's at mid 150's mph back in October. I don't know what it weighed when it made that run. The weight limit is now 3350.
#1993345
01/18/16 03:08 PM
01/18/16 03:08 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
What heads do the drag pak run? The coyote head will not keep up with any new hemi head except the early 5.7, that is going to be the difference. Chevy does have heads that can get closer to the apatch/hellcat/eagle/6.1 heads. Without a weight break the coyote will be at the back of the pack, the 4 valves DOHC is nice but you can only turn the RPM so far with limited head flow.
