Spark Plug Wires - Whats the deal ? #197583
01/18/09 09:24 PM
01/18/09 09:24 PM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hi guys,
I want you to share your opinion and experiences on spark plug wires.
IMO the less resistance on the wire better.
So, no talk about "suppressing" and so on. The less ohm/feet better. Is it rigth?
Sure we have to consider somethings about eletromagnetic field created on some wires that could interfer on eletronics stuff like EFI.
What do you think? Which set of wires do you use? Any proven difference on dyno have been showed changing wires ?
BR,
Fernando
Re: Spark Plug Wires - Whats the deal ? [Re: dart_73_br] #197584
01/18/09 09:27 PM
01/18/09 09:27 PM
Kirkland, Washington
Pacnorthcuda Offline
I run a MSD 6AL so I use Taylor Spiro Pros. Other wise I would run solids.
Re: Spark Plug Wires - Whats the deal ? [Re: Pacnorthcuda] #197585
01/18/09 09:34 PM
01/18/09 09:34 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
from what i have been hearing Firecore 50 wires are the way to go. hes a member here sunroofgtx?
Re: Spark Plug Wires - Whats the deal ? [Re: dart_73_br] #197586
01/18/09 09:46 PM
01/18/09 09:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Apparently there`s more to wires than just resistance I`m no expert but you`ll be hearing all about it shortly I`m sure. I`m using the firecore 50`s and they seem to be working well.
Re: Spark Plug Wires - Whats the deal ? [Re: Thumperdart] #197587
01/18/09 11:45 PM
01/18/09 11:45 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I just bought a set of Firecores for my street car and will replace my MSD wires with them next year in my street/strip car. And yes, you should be getting a short written demonstration soon, Hi Rick
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Spark Plug Wires - Whats the deal ? [Re: G-Money1320] #197588
01/19/09 01:32 PM
01/19/09 01:32 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I run the firecores on my small block and they work great.
I plan on EFI for my Big Block
Surely we have to consider somethings about eletromagnetic field created on some wires that could interfer on eletronics stuff like EFI.
I am interested in this question as well.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Spark Plug Wires - Whats the deal ? [Re: Kam*Kuda] #197589
01/19/09 01:57 PM
01/19/09 01:57 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Run some solid cores and turn on the radio...
I just run quality spiral cores and have never had problems. Unless you're racing I doubt you could tell the difference between 500 ohms/ft and 50 ohms/ft wires. The difference in voltage drop across the wire compared to the spark gasp is very small. If you run the old carbon core wires at 10,000 ohms you can feel the difference.
Re: Spark Plug Wires - Whats the deal ? [Re: Kam*Kuda] #197590
01/19/09 01:57 PM
01/19/09 01:57 PM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
For the most part its alot of hype, not more than a couple horsepower between any wire.
Re: Spark Plug Wires - Whats the deal ? [Re: hemi471] #197591
01/19/09 02:12 PM
01/19/09 02:12 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I agree. Comparing like quality will reveal little difference. We use Moroso but the Firecores are also very good.
Re: Spark Plug Wires - Whats the deal ? [Re: BobR] #197592
01/19/09 02:22 PM
01/19/09 02:22 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i like the MSD's but may try the Firecores when the MSD's get old, if the price is about the same.
Re: Spark Plug Wires - Whats the deal ? [Re: ademon] #197593
01/19/09 02:33 PM
01/19/09 02:33 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
I donīt want to hear a Radio on my Dart... just the sound of the engine...
Iīm just worried about the interference on my EFI circuit.
Re: Spark Plug Wires - Whats the deal ? [Re: ademon] #197594
01/19/09 02:40 PM
01/19/09 02:40 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
if I could run solid wires I would. but Mallory says not to with their hyfire box so I wont. I would run them with a chrome box though without hesitation.
As for resistance, just remember this, before the plug fires, there is an OPEN circuit. Infinite resistance. Once the arc has sparked, and the wire starts conducting, the resistance goes down.
theres a lot of complicated math and engineering behind a spark plug firing but to make it stupidly simple, lets assume its as simple as ohms law.
if you do, you can see the difference in spark voltage between a 50 ohm wire and a 500 ohm wire is negligable at a given current. E=ir so figure a 1 amp current (not sure what it is in the real world but 1 amp is close enough for this calculation). lets use a firing voltage of 20,000v (just picked it out of my butt)
with a 40ohm wire, that would give you the voltage at the plug as 1amp=(20,000-x)/40 so x=19,960v
using a 400ohm wire, you get 19,600v firing at the plug. not much of a difference in the real world.
With that said, im sure I made a mistake somewhere and someone more experienced than me will correct me.
I will say that am running the firecores and like them alot
Re: Spark Plug Wires - Whats the deal ? [Re: dart_73_br] #197595
01/19/09 03:05 PM
01/19/09 03:05 PM
michigan
64ssmax Offline
64ssmax  Offline
michigan
dart_73,
PM jake68, he has great knowledge on this issue!
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
Re: Spark Plug Wires - Whats the deal ? [Re: 64ssmax] #197596
01/19/09 04:05 PM
01/19/09 04:05 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Firecores, Sunroofgtx great to deal with! Bought a set last year.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Spark Plug Wires - Whats the deal ? [Re: 11secdart] #197597
01/19/09 04:12 PM
01/19/09 04:12 PM
California, USA
blairboy3 Offline
blairboy3  Offline
California, USA
I'm running Moroso Ultra40's. So far, the best wire I've ran on my Fury. I tried Accel's, MSD's, & Taylor.
I did have a set of the Firecores when I first built the engine. But, to be fair, I shouldn't have used them for the break in. The heat from the headers killed them & caused the terminals to seperate from the wires when I tried to the change the plugs. I do want to try them again now that it's broken in, but I need to wait for the Ultra40's to go south first.
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
Re: Spark Plug Wires - Whats the deal ? [Re: blairboy3] #197598
01/19/09 04:24 PM
01/19/09 04:24 PM
Idaho
Runner Offline
Runner  Offline
Idaho
on my junk, ive ran solid core jacobs, ive also ran msd's, taylors, mallory sidwiinders, and moroso wires and there wasn't a lick of et difference between any of them.
if i wanted a good blacvk wire id most likly go with the firecores to support them, but i like red wires so i typically run moroso's
Re: Spark Plug Wires - Whats the deal ? [Re: Runner] #197599
01/19/09 07:11 PM
01/19/09 07:11 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
Firecore here great wires and price
Re: Spark Plug Wires - Whats the deal ? [Re: MOPARCHAS] #197600
01/19/09 11:59 PM
01/19/09 11:59 PM
land of the free
ts racer Offline
ts racer  Offline
land of the free
has anybody done any runs or dyno tests with different wires?
Re: Spark Plug Wires - Whats the deal ? [Re: dart_73_br] #197601
01/20/09 12:09 AM
01/20/09 12:09 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
there's a reason the electronics manufacturers warn against using solid core wires and it's not to sell you supression wires. anyone that's been in the automotive field long enough has seen problems due to either bad wires and/or solid core wires when using electronics. for a magneto or old breaker type ignition they're fine but for anything else with electronics you need a quality supression wire. imho there's darn little if any difference between any of the quality wires out there and installation is more important than the wire at that point. how many factories can possibly be making the bulk wire anyhow? there's a lot of "branding" and marketing going on.
Re: Spark Plug Wires - Whats the deal ? [Re: ts racer] #197602
01/20/09 12:17 AM
01/20/09 12:17 AM
California, USA
blairboy3 Offline
blairboy3  Offline
California, USA
There was a thread a couple months ago where one of the engine builders here ran ... I think... moroso's against the firecores. The firecores made a few more hp.
