Re: Spark Plug Wires - Whats the deal ?
[Re: dart_73_br]
#197586
01/18/09 09:46 PM
01/18/09 09:46 PM
Thumperdart
State of confusion
Apparently there`s more to wires than just resistance I`m no expert but you`ll be hearing all about it shortly I`m sure. I`m using the firecore 50`s and they seem to be working well.
[Re: G-Money1320]
#197588
01/19/09 01:32 PM
01/19/09 01:32 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
I run the firecores on my small block and they work great. I plan on EFI for my Big Block Quote:
Surely we have to consider somethings about eletromagnetic field created on some wires that could interfer on eletronics stuff like EFI.
I am interested in this question as well.
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Kam*Kuda]
#197589
01/19/09 01:57 PM
01/19/09 01:57 PM
Posts: 6,516 Santa Cruz, California
Lefty
Run some solid cores and turn on the radio...
I just run quality spiral cores and have never had problems. Unless you're racing I doubt you could tell the difference between 500 ohms/ft and 50 ohms/ft wires. The difference in voltage drop across the wire compared to the spark gasp is very small. If you run the old carbon core wires at 10,000 ohms you can feel the difference.
[Re: ademon]
#197594
01/19/09 02:40 PM
01/19/09 02:40 PM
Posts: 15,491 the boonies
aarcuda
the boonies
if I could run solid wires I would. but Mallory says not to with their hyfire box so I wont. I would run them with a chrome box though without hesitation.
As for resistance, just remember this, before the plug fires, there is an OPEN circuit. Infinite resistance. Once the arc has sparked, and the wire starts conducting, the resistance goes down.
theres a lot of complicated math and engineering behind a spark plug firing but to make it stupidly simple, lets assume its as simple as ohms law.
if you do, you can see the difference in spark voltage between a 50 ohm wire and a 500 ohm wire is negligable at a given current. E=ir so figure a 1 amp current (not sure what it is in the real world but 1 amp is close enough for this calculation). lets use a firing voltage of 20,000v (just picked it out of my butt)
with a 40ohm wire, that would give you the voltage at the plug as 1amp=(20,000-x)/40 so x=19,960v
using a 400ohm wire, you get 19,600v firing at the plug. not much of a difference in the real world.
With that said, im sure I made a mistake somewhere and someone more experienced than me will correct me.
I will say that am running the firecores and like them alot
[Re: dart_73_br]
#197595
01/19/09 03:05 PM
01/19/09 03:05 PM
Posts: 351 michigan
64ssmax
michigan
dart_73,
PM jake68, he has great knowledge on this issue!
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
[Re: 64ssmax]
#197596
01/19/09 04:05 PM
01/19/09 04:05 PM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
Firecores, Sunroofgtx great to deal with! Bought a set last year.
[Re: 11secdart]
#197597
01/19/09 04:12 PM
01/19/09 04:12 PM
Posts: 2,179 California, USA
blairboy3
California, USA
I'm running Moroso Ultra40's. So far, the best wire I've ran on my Fury. I tried Accel's, MSD's, & Taylor.
I did have a set of the Firecores when I first built the engine. But, to be fair, I shouldn't have used them for the break in. The heat from the headers killed them & caused the terminals to seperate from the wires when I tried to the change the plugs. I do want to try them again now that it's broken in, but I need to wait for the Ultra40's to go south first.
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
[Re: dart_73_br]
#197601
01/20/09 12:09 AM
01/20/09 12:09 AM
Posts: 5,875 communist bloc of new jersey
jamesc
So, no talk about "suppressing" and so on.
there's a reason the electronics manufacturers warn against using solid core wires and it's not to sell you supression wires. anyone that's been in the automotive field long enough has seen problems due to either bad wires and/or solid core wires when using electronics. for a magneto or old breaker type ignition they're fine but for anything else with electronics you need a quality supression wire. imho there's darn little if any difference between any of the quality wires out there and installation is more important than the wire at that point. how many factories can possibly be making the bulk wire anyhow? there's a lot of "branding" and marketing going on.
