Denso alternators on big blocks #1972271
12/18/15 07:15 PM
12/18/15 07:15 PM
USA
rftroy Offline OP
rftroy  Offline OP
USA
I'm looking into options for mounting a Denso alternator onto a big block in my 70 Challenger.
Andy has a kit for the Toyota alternator, but that alt. only seems to come in 60 A form.
Is there another, higher amp rating, model that anyone knows of that will fit Andy's bracketry?
What other options are available?
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Denso alternators on big blocks [Re: rftroy] #1972330
12/18/15 09:53 PM
12/18/15 09:53 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I bought a kit from Mancini that Andy makes for a large Denso alt. This was a couple of years ago, so I'd check there. HTH, Steve
Re: Denso alternators on big blocks [Re: rftroy] #1972400
12/18/15 11:31 PM
12/18/15 11:31 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Companies like Powermaster have several high output Denso alternators. They have internal and externally regulated models. I bought my bracket from Mancini. The stock Mopar top bracket still fits but the bottom adjuster bracket is what's really different. It's got a different arch due to the smaller diameter of the alternator.
Re: Denso alternators on big blocks [Re: shorthorse] #1972408
12/18/15 11:45 PM
12/18/15 11:45 PM
USA
rftroy Offline OP
rftroy  Offline OP
USA
shorthorse,
Thanks! That is exactly the information I was looking for.
I put a Denso on my slant 6 car, and I had to mill down the mount a bit to get things lined up. Quite a pain surveying the engine.
I have the 120 A Denso with a v-groove pulley from a Dodge truck. With these drawings, I should be able to figure what modifications to make to brackets without another cumbersome survey.
Bob
Re: Denso alternators on big blocks [Re: rftroy] #1972411
12/18/15 11:49 PM
12/18/15 11:49 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Can anyone tell me if there's a two groove pulley Denso?
Re: Denso alternators on big blocks [Re: TooMany62s] #1972414
12/18/15 11:53 PM
12/18/15 11:53 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
Here ya go!!!
I am running this with Andy's brackets, It's a 120Amp unit for a John Deere tractor, you have to just cut down the housing studs on the back and fits right in place! It's much deeper than a standard Denso, but everything else is the same.
Ryan
http://www.amazon.com/DB-Electrical-AND0...ator+John+Deere
Re: Denso alternators on big blocks [Re: TooMany62s] #1972420
12/19/15 12:05 AM
12/19/15 12:05 AM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Pulleys are readily available in all different configurations for Denso alternators. Just check your shaft size. Some factory replacement units come with the matching pulley and some units are sold without a pulley. With some aftermarket units, you specify what pulley you want and they will deliver it as you requested. When replacing or installing a new pulley yourself, do it per the manufacturers instructions otherwise you can damage the armature or the brush mechanism. NO Hammers!
