Denso alternators on big blocks
#1972271
12/18/15 07:15 PM
12/18/15 07:15 PM
Posts: 704 USA
rftroy
USA
I'm looking into options for mounting a Denso alternator onto a big block in my 70 Challenger. Andy has a kit for the Toyota alternator, but that alt. only seems to come in 60 A form. Is there another, higher amp rating, model that anyone knows of that will fit Andy's bracketry?
What other options are available?
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Denso alternators on big blocks
[Re: shorthorse]
#1972408
12/18/15 11:45 PM
12/18/15 11:45 PM
Posts: 704 USA
rftroy
USA
shorthorse,
Thanks! That is exactly the information I was looking for. I put a Denso on my slant 6 car, and I had to mill down the mount a bit to get things lined up. Quite a pain surveying the engine.
I have the 120 A Denso with a v-groove pulley from a Dodge truck. With these drawings, I should be able to figure what modifications to make to brackets without another cumbersome survey.
Bob
[Re: TooMany62s]
#1972414
12/18/15 11:53 PM
12/18/15 11:53 PM
Posts: 305 5th and plum
redmist
5th and plum
Can anyone tell me if there's a two groove pulley Denso? Here ya go!!! I am running this with Andy's brackets, It's a 120Amp unit for a John Deere tractor, you have to just cut down the housing studs on the back and fits right in place! It's much deeper than a standard Denso, but everything else is the same. Ryan http://www.amazon.com/DB-Electrical-AND0...ator+John+Deere
[Re: TooMany62s]
#1972420
12/19/15 12:05 AM
12/19/15 12:05 AM
Posts: 360 Ohio
shorthorse
Ohio
Can anyone tell me if there's a two groove pulley Denso? Pulleys are readily available in all different configurations for Denso alternators. Just check your shaft size. Some factory replacement units come with the matching pulley and some units are sold without a pulley. With some aftermarket units, you specify what pulley you want and they will deliver it as you requested. When replacing or installing a new pulley yourself, do it per the manufacturers instructions otherwise you can damage the armature or the brush mechanism. NO Hammers!
