Gen III hemi and 727- Are you satisfied? #1950866
11/14/15 01:22 AM
11/14/15 01:22 AM
USA
hudsonhornet7x Offline OP
USA
For those of you using a 727 behind your hemi, are you satisfied with the performance you are getting?
What stall and what rear gear?
Does a high stall make it feel "mushy" around town?
I am trying to make a decision for my Charger. Thanks!
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1950887
11/14/15 02:03 AM
11/14/15 02:03 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
What size engine are you building?
I have to same converter that was behind my 700hp 493. Its a 9" ultimate
It had 3.55 gears and felt so slow. The 410s in it now feel much better however i ran slower at DW for whatever reason. It never really feels mushy
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1950888
11/14/15 02:07 AM
11/14/15 02:07 AM
USA
USA
I am building a 6.4.
I want a good balance of strip power, and not revving the engine to the moon on a highway trip. I would go to an overdrive if I could find something strong that would not take butchering the floor.
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1950891
11/14/15 02:12 AM
11/14/15 02:12 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
There wasnt that much difference it seems when i had 355s to now with 410s and a gear vender driving down the highway.
I got 16mpg when i drove like a regular person. 14.5 when driving like the idiot i am with 410s and OD
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1950895
11/14/15 02:28 AM
11/14/15 02:28 AM
USA
USA
Thanks for the info. Just out of curiosity, how does the gen III in your car compare to the big block you had in it before.
Things like off the line grunt, etc?
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1950908
11/14/15 02:51 AM
11/14/15 02:51 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
With 3" exhaust its only a 1/10 slower but if i opened the cutouts on the BB then the gap gets alot bigger.
The hemi feels alot slower but its not
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1951061
11/14/15 02:16 PM
11/14/15 02:16 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I have NAG1 behind a 5.7 in a 70 GTX. I used 2:76 gears to start so it would be comparable to the donor car...ease of swap ill-logic:)....anyway, yes, I had to raise the hump about 3/4" but it was no big deal. The computer WAS an issue but that is easily overcome with an after market TCM. This car will absolutely beat snot out of the 440/727 set up it came with. I have not messed with the gears or done anything to the engine performance wise...yet...just wanted to get it all working first. I'm not a racer so that wasn't any goal I had in mind, however, this car is plenty fast, is an awesome cruise, and gets 20mpg! 73mph at 2000rpm.
Driving modern convenience in classic beauty
Re: Gen III hemi and 727- Are you satisfied? [Re: sixpackgut] #1951104
11/14/15 03:28 PM
11/14/15 03:28 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Probably the hemi has a smoother and wider power band?
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1951116
11/14/15 04:04 PM
11/14/15 04:04 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I'd guess the 493 would have a wider power band due to be extra cubes, the extra low end grunt probably helps the seat of the pants, the Gen III is probably like the Gen II is, you have to buzz them up to get the good stuff
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1958518
11/26/15 09:35 PM
11/26/15 09:35 PM
Detroit
Dave04 Offline
Dave04  Offline
Detroit
So with an electronic throttle body, what are you guys using for a kick down on a 727? I'm looking to put a 6.1 in front of my 727 in a Ramcharger...
1979 Ramcharger, 360/727/HD44F/D60R 1968 GTX, 440/727/8.75
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1963789
12/05/15 03:08 PM
12/05/15 03:08 PM
Burbank Ca
bkilby Offline
bkilby  Offline
Burbank Ca
I'd like to hear some input too. I have a Gen3 426 I'd like to put in front of my A518 but haven't heard of a good solution for the kick down. I know you can get the APP Sensor and adjustable cable but I can't imagine there's not a better option.
'73 340 Challenger and then some.
Re: Gen III hemi and 727- Are you satisfied? [Re: bkilby] #1963815
12/05/15 04:00 PM
12/05/15 04:00 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Could one not run a Lokar throttle cable on the throttle cable and run it to the kick down when using an electronic throttle body?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1968428
12/12/15 04:11 PM
12/12/15 04:11 PM
Burbank Ca
bkilby Offline
bkilby  Offline
Burbank Ca
Anyone?
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1968440
12/12/15 04:24 PM
12/12/15 04:24 PM
cincinnati ohio
mcat4321 Online content
mcat4321  Online Content
cincinnati ohio
i run a 727 and i am happy.. i do use a cable driven TB ; i modified it to use a lokar kickdown cable. all seem fine
Re: Gen III hemi and 727- Are you satisfied? [Re: hudsonhornet7x] #1968887
12/13/15 01:01 PM
12/13/15 01:01 PM
Burbank Ca
bkilby Offline
bkilby  Offline
Burbank Ca
How did you modify it? Got a pic handy?
Re: Gen III hemi and 727- Are you satisfied? [Re: bkilby] #1969225
12/14/15 12:12 AM
12/14/15 12:12 AM
cincinnati ohio
cincinnati ohio
no, but i will get one and post it.
Re: Gen III hemi and 727- Are you satisfied? [Re: bkilby] #1970264
12/15/15 05:21 PM
12/15/15 05:21 PM
cincinnati ohio
cincinnati ohio
if it works its not silly, it works awesome 1/4" thumb screw
20151215_140931_resized.jpg20151215_140936_resized.jpg20151215_140952_resized.jpg20151215_140947_resized.jpg
Re: Gen III hemi and 727- Are you satisfied? [Re: mcat4321] #1985482
01/07/16 12:18 PM
01/07/16 12:18 PM
michigan
440whiteboy Offline
440whiteboy  Offline
michigan
what are you motor mounts -
are you runnin and is this in your challenger?
They only see Stars...
when hit by a Mopar!
Re: Gen III hemi and 727- Are you satisfied? [Re: Darius] #1986991
01/09/16 05:14 PM
01/09/16 05:14 PM
texas
462hemi Offline
462hemi  Offline
texas
when you say you had to raise the hump about 3/4", what do you mean? i am looking very hard at putting a nag in my satellite....but wasnt sure if i had to really butcher up the trans tunnel or fab a new one all together. how did you do yours?
462 gen 3 hemi daily driven
