Re: Gen III hemi and 727- Are you satisfied?
[Re: hudsonhornet7x]
#1950887
11/14/15 02:03 AM
11/14/15 02:03 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
What size engine are you building?
I have to same converter that was behind my 700hp 493. Its a 9" ultimate
It had 3.55 gears and felt so slow. The 410s in it now feel much better however i ran slower at DW for whatever reason. It never really feels mushy
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#1950891
11/14/15 02:12 AM
11/14/15 02:12 AM
sixpackgut
Charleston
There wasnt that much difference it seems when i had 355s to now with 410s and a gear vender driving down the highway.
I got 16mpg when i drove like a regular person. 14.5 when driving like the idiot i am with 410s and OD
#1950908
11/14/15 02:51 AM
11/14/15 02:51 AM
sixpackgut
Charleston
With 3" exhaust its only a 1/10 slower but if i opened the cutouts on the BB then the gap gets alot bigger.
The hemi feels alot slower but its not
#1951061
11/14/15 02:16 PM
11/14/15 02:16 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I have NAG1 behind a 5.7 in a 70 GTX. I used 2:76 gears to start so it would be comparable to the donor car...ease of swap ill-logic:)....anyway, yes, I had to raise the hump about 3/4" but it was no big deal. The computer WAS an issue but that is easily overcome with an after market TCM. This car will absolutely beat snot out of the 440/727 set up it came with. I have not messed with the gears or done anything to the engine performance wise...yet...just wanted to get it all working first. I'm not a racer so that wasn't any goal I had in mind, however, this car is plenty fast, is an awesome cruise, and gets 20mpg! 73mph at 2000rpm.
Driving modern convenience in classic beauty
[Re: sixpackgut]
#1951104
11/14/15 03:28 PM
11/14/15 03:28 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
The hemi feels alot slower but its not Probably the hemi has a smoother and wider power band?
#1958518
11/26/15 09:35 PM
11/26/15 09:35 PM
Posts: 24 Detroit
Dave04
Detroit
So with an electronic throttle body, what are you guys using for a kick down on a 727? I'm looking to put a 6.1 in front of my 727 in a Ramcharger...
1979 Ramcharger, 360/727/HD44F/D60R
1968 GTX, 440/727/8.75
#1963789
12/05/15 03:08 PM
12/05/15 03:08 PM
Posts: 33 Burbank Ca
bkilby
Burbank Ca
I'd like to hear some input too. I have a Gen3 426 I'd like to put in front of my A518 but haven't heard of a good solution for the kick down. I know you can get the APP Sensor and adjustable cable but I can't imagine there's not a better option.
'73 340 Challenger and then some.
[Re: bkilby]
#1963815
12/05/15 04:00 PM
12/05/15 04:00 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'd like to hear some input too. I have a Gen3 426 I'd like to put in front of my A518 but haven't heard of a good solution for the kick down. I know you can get the APP Sensor and adjustable cable but I can't imagine there's not a better option. Could one not run a Lokar throttle cable on the throttle cable and run it to the kick down when using an electronic throttle body?
#1968887
12/13/15 01:01 PM
12/13/15 01:01 PM
bkilby
Burbank Ca
How did you modify it? Got a pic handy?
[Re: bkilby]
#1969225
12/14/15 12:12 AM
12/14/15 12:12 AM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
How did you modify it? Got a pic handy? no, but i will get one and post it.
[Re: bkilby]
#1970264
12/15/15 05:21 PM
12/15/15 05:21 PM
mcat4321
cincinnati ohio
How did you modify it? Got a pic handy? if it works its not silly, it works awesome 1/4" thumb screw
[Re: mcat4321]
#1985482
01/07/16 12:18 PM
01/07/16 12:18 PM
Posts: 1,106 michigan
440whiteboy
michigan
How did you modify it? Got a pic handy? if it works its not silly, it works awesome 1/4" thumb screw what are you motor mounts - are you runnin and is this in your challenger?
They only see Stars... when hit by a Mopar!
[Re: Darius]
#1986991
01/09/16 05:14 PM
01/09/16 05:14 PM
Posts: 46 texas
462hemi
texas
I have NAG1 behind a 5.7 in a 70 GTX. I used 2:76 gears to start so it would be comparable to the donor car...ease of swap ill-logic:)....anyway, yes, I had to raise the hump about 3/4" but it was no big deal. The computer WAS an issue but that is easily overcome with an after market TCM. This car will absolutely beat snot out of the 440/727 set up it came with. I have not messed with the gears or done anything to the engine performance wise...yet...just wanted to get it all working first. I'm not a racer so that wasn't any goal I had in mind, however, this car is plenty fast, is an awesome cruise, and gets 20mpg! 73mph at 2000rpm. when you say you had to raise the hump about 3/4", what do you mean? i am looking very hard at putting a nag in my satellite....but wasnt sure if i had to really butcher up the trans tunnel or fab a new one all together. how did you do yours?
462 gen 3 hemi daily driven
