1971 Roadrunner heater core question #1968540
12/12/15 07:30 PM
12/12/15 07:30 PM
North Central Florida
E
eightlitermopar Offline OP
E
My 1971 RR heater core finally sprung a leak. All the replacements I find online are for cars WITH a/c.
My RR is a non-ac car.
Does my car have the same heater core with or without A/C?
For example I was looking at this: http://www.oreillyauto.com/site/c/detail...ord=heater+core
Also, I have never taken out a heater core. Does it really suck as bad as I have been told?
eightlitermopar
Mopar or no car
Re: 1971 Roadrunner heater core question [Re: eightlitermopar] #1968581
12/12/15 09:09 PM
12/12/15 09:09 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Send it to Glen Ray radiator and let them fix it, then you can sleep good knowing that it is the right one in your car.
Re: 1971 Roadrunner heater core question [Re: eightlitermopar] #1968632
12/12/15 10:47 PM
12/12/15 10:47 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
(I'd pull it, and take it to your friendly neighborhood rad shop...
You might get out of it easy...)
Re: 1971 Roadrunner heater core question [Re: eightlitermopar] #1968676
12/12/15 11:49 PM
12/12/15 11:49 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
A/C is different than non-a/c. I got a Spectra perineum from Autozone for mine. Fit like a glove.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1971 Roadrunner heater core question [Re: eightlitermopar] #1968681
12/12/15 11:55 PM
12/12/15 11:55 PM
moparmarks Offline
moparmarks  Offline
I just checked Autozone and Rockauto and both are out of them. NAPA has them.
http://www.napaonline.com/Catalog/Result...2821/Ne-1000000
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 1971 Roadrunner heater core question [Re: moparmarks] #1968683
12/12/15 11:55 PM
12/12/15 11:55 PM
use your old heater hoses on the firewall nipples & modulate your garden hose psi to flush the antifreeze out of the core to elim any of it getting on the carpet etc when you pull/tip the heater box for removal (low psi-its already leaking)
Re: 1971 Roadrunner heater core question [Re: RapidRobert] #1969262
12/14/15 01:20 AM
12/14/15 01:20 AM
E
E
Thanks for the heads up! I will block it off for now. I don't really need it currently in Florida, I just don't want the thing leaking. Now I have another thing to add to my list.
thanks again
eight
Mopar or no car
