Z Bar clip #1965080
12/07/15 07:54 PM
12/07/15 07:54 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
My first 4 speed.
We have everything apart and a new rebuild kit for the Z bar. Does this clip go into the holes that are in the sides of the Ball Stud Bearings once you slide everything into the Z bar? I would call them nylon bushings, whatever I guess. We know which ball stud they go on and which side of the Z bar that it goes into.
This appeared to be way it was assembled when we pulled it apart.
Another question. How do you get the rubber seal over the ball stud? I thought about heating it and then using dish soap or Windex to get it to stretch and slide over.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Z Bar clip [Re: cdstl] #1965121
12/07/15 09:07 PM
12/07/15 09:07 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Yes, if you look at the outside of the nylon bushings you'll see a groove cut into it, that's where the tips of the clip slide in. Can't remember on the rubber seal, been too long - will it slide over the threaded end before you screw it in? (I'm thinking I just stretched it over the ball end, but like I said, it was a long time ago.)
Re: Z Bar clip [Re: cdstl] #1965272
12/08/15 12:22 AM
12/08/15 12:22 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You grease the ball and push the rubber seal over it. Warming it up in boiling water might help soften it but I never bothered with that.
Re: Z Bar clip [Re: cdstl] #1965276
12/08/15 12:25 AM
12/08/15 12:25 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
OK, thanks everyone.
