Z Bar clip
#1965080
12/07/15 07:54 PM
12/07/15 07:54 PM
Posts: 1,487 STL
cdstl
STL
My first 4 speed. We have everything apart and a new rebuild kit for the Z bar. Does this clip go into the holes that are in the sides of the Ball Stud Bearings once you slide everything into the Z bar? I would call them nylon bushings, whatever I guess. We know which ball stud they go on and which side of the Z bar that it goes into. This appeared to be way it was assembled when we pulled it apart. Another question. How do you get the rubber seal over the ball stud? I thought about heating it and then using dish soap or Windex to get it to stretch and slide over. Thanks
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
