Yes, if you look at the outside of the nylon bushings you'll see a groove cut into it, that's where the tips of the clip slide in. Can't remember on the rubber seal, been too long - will it slide over the threaded end before you screw it in? (I'm thinking I just stretched it over the ball end, but like I said, it was a long time ago.)
