1972 U-Code B-Body 4 Spd Fact
#1964942
12/07/15 03:53 PM
12/07/15 03:53 PM
Posts: 2,149 Bristol, CT
RalphsRapidTrnst
Bristol, CT
This past weekend I picked up the final peices to my next project 1972 Charger Rallye 440 4Spd. I was talking to the owner who ordered the Charger New in 1972. I asked, "why didn't you get the exhaust tips" He told me he couldn't? They were not available with the 440 4Spd option. He would of had to go with a 440 Auto or 400 4Spd if he wanted the exhasut tips. I thought that was interesting. I figured must be a sales man goof. Then on my ride home I remember my 1972 RR/GTX 440 4Spd. has no tips? Is this true? Any thoughts from the Moparts guru's.
Is this true, if you wanted a 440 4Spd B-Body in 1972 you did not have the option of getting exhaust tips? Any other survivor owners out there have a 1972 440 4Spd Body with no tips?
Re: Possible 1972 U-Code B-Body 4 Spd Fact
[Re: Alaskan_TA]
#1964960
12/07/15 04:26 PM
12/07/15 04:26 PM
RalphsRapidTrnst
Bristol, CT
YUP! U are the man TY... Will change the post to FACT! Same deal for Plymouth?
[Re: RalphsRapidTrnst]
#1964971
12/07/15 04:35 PM
12/07/15 04:35 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
I have four 72 440 four speed STL built Road Runners on file. None code N42. The 440 automatics do. It appears that Windsor plant did not code N42 regardless of transmission.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: Rhinodart]
#1965668
12/08/15 04:43 PM
12/08/15 04:43 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
So someone give a good conjecture as to why they COULDN'T work with a 4-speed? Worked fine in '71... Although, 6-bbl. and Hemi had resonators... The only restriction I know of in '71 was N/A on the west coast due to 'noise'... Maybe that intensified in '72... Which leads to the next question... What about '73???
[Re: Rhinodart]
#1965699
12/08/15 05:08 PM
12/08/15 05:08 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
So someone give a good conjecture as to why they COULDN'T work with a 4-speed? The tips are probably a noise related restriction, Kalifornia banned them even with automatics. I've often wondered about those accessory restrictions too. Lots of them make no sense....like no A/C with the 440HP and 4-speed.
[Re: RSNOMO]
#1965770
12/08/15 06:36 PM
12/08/15 06:36 PM
1969HEMI
1969HEMI
So someone give a good conjecture as to why they COULDN'T work with a 4-speed? Worked fine in '71... Although, 6-bbl. and Hemi had resonators... The only restriction I know of in '71 was N/A on the west coast due to 'noise'... Maybe that intensified in '72... Which leads to the next question... What about '73??? Easy answer to the last question. Nobody cares about any cars built after 1972.................................. ...
[Re: 69CoronetRT]
#1967346
12/10/15 09:17 PM
12/10/15 09:17 PM
Posts: 3,334 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
I have four 72 440 four speed STL built Road Runners on file. None code N42. The 440 automatics do. It appears that Windsor plant did not code N42 regardless of transmission. 19 U code 4spd runners (72) on file here, none with N42.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: Diego (not Ted)]
#1967615
12/11/15 10:40 AM
12/11/15 10:40 AM
Posts: 595 Nashville, Tennessee
Tempest
Lots of them make no sense....like no A/C with the 440HP and 4-speed. It's because Ma Mopar equipped them with 3.54 gears standard. Few cars during the era were available with AC and those gears. Same with GM. They did not want to warranty AC compressors with the higher RPM. So standard with AC was 3.08.
[Re: Butterscotch71]
#1967664
12/11/15 12:35 PM
12/11/15 12:35 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
I have four 72 440 four speed STL built Road Runners on file. None code N42. The 440 automatics do. It appears that Windsor plant did not code N42 regardless of transmission. 19 U code 4spd runners (72) on file here, none with N42. There's one in town here that hasn't moved in years. I bet it's not on your list.
[img] [/img]
[Re: Rhinodart]
#1968131
12/12/15 01:10 AM
12/12/15 01:10 AM
Posts: 422 wisconsin united states
keith airgrabber
Right in the Nutz!!!
Interesting.I have a 72 gtx 4-speed. I don't have tips either. Always thought they just weren't ordered. I don't recall ever seeing tips on a 440 72 car now that i think about it. Weird . I thought maybe in California You couldn't get tips.
[Re: Tempest]
#1968207
12/12/15 03:36 AM
12/12/15 03:36 AM
Posts: 22,900 Gabba Gabba Hey! NYC
Diego (not Ted)
Perhaps for a car you're thinking of, but not true as a blanket statement.
[Re: keith airgrabber]
#1968373
12/12/15 02:44 PM
12/12/15 02:44 PM
Posts: 765 Shoreline, Washington
72roadrunnergtx
Interesting.I have a 72 gtx 4-speed. I don't have tips either. Always thought they just weren't ordered. I don't recall ever seeing tips on a 440 72 car now that i think about it. Weird . I thought maybe in California You couldn't get tips. My California spec ’72 RR/GTX Auto, came with tips originally.
