Harbor Freight Standard Transmission floor lift #1963668
12/05/15 12:10 PM
12/05/15 12:10 PM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Has any one used a Standard Transmission Floor Lift that Harbor Freight sells ? They are $99 and I have a 20% off coupon !!!
Thanks Tom C.
Re: Harbor Freight Standard Transmission floor lift [Re: TOMRR] #1963678
12/05/15 12:29 PM
12/05/15 12:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have had their tall trans jack for years. Takes a fair amount of strokes to pump it up. It's not the worlds most heavy duty but it get's the job done.
Doug
Re: Harbor Freight Standard Transmission floor lift [Re: dvw] #1963688
12/05/15 12:37 PM
12/05/15 12:37 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have this one and LOVE the heck out of it. I work without a lift so this really helps. As with most of their products I took it apart and cleaned the shavings out of it and applied grease to the screw and DON"T force it past its upper and lower limits. When it stops, stop.
http://www.harborfreight.com/450-lb-low-lift-transmission-jack-61232.html
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Harbor Freight Standard Transmission floor lift [Re: TOMRR] #1963689
12/05/15 12:39 PM
12/05/15 12:39 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have a low-lift hydraulic and the scissor jack. For working on jack stands, I go for the scissor jack the majority of the time.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Harbor Freight Standard Transmission floor lift [Re: pittsburghracer] #1963697
12/05/15 12:51 PM
12/05/15 12:51 PM
IN
ahy Offline
ahy  Offline
IN
I have one similar. Works great for car transmissions.
I used it for the iron transmission on a '47 PW (heavy and high) and it was a bit wobbly. For PU's really need something wider and heavier.
Re: Harbor Freight Standard Transmission floor lift [Re: TOMRR] #1963766
12/05/15 02:23 PM
12/05/15 02:23 PM
BDW Offline
BDW  Offline
I bought one when I did my 518 swap.  It's a little wobbly and hard to get moving up when it's fully seated with the tranny on it.  It did the trick for a shade tree mechanic like me that only expects to use it once in a while.
I would suggest something better if you will be using it all the time.
Re: Harbor Freight Standard Transmission floor lift [Re: pittsburghracer] #1963796
12/05/15 03:22 PM
12/05/15 03:22 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I have the same one, works great and haven't had any problem with it. up
Re: Harbor Freight Standard Transmission floor lift [Re: TOMRR] #1963800
12/05/15 03:33 PM
12/05/15 03:33 PM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Well I went to Harbor Freight and got one and hade a 20% off coupon. I think it going to work just fine !!!
Thanks for All The Replies Tom C.
Re: Harbor Freight Standard Transmission floor lift [Re: TOMRR] #1963986
12/05/15 08:45 PM
12/05/15 08:45 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Just bought one a few weeks ago...used it on a 46RE in my 99 Dodge Ram...worked great..
Had previously borrowed one and it worked just fine also.
Tony
70 AARCuda Vitamin C
Re: Harbor Freight Standard Transmission floor lift [Re: 70AARcuda] #1964032
12/05/15 10:39 PM
12/05/15 10:39 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Well, I'm gonna be on the opposite side of the street with this one.
Maybe they improved on the design of these things, when i owned one, bought one, 10 years ago, but it was the most worthless piece of schlitz that i bought from Harbor Freight.
It wouldn't handle the Mopar 4 speed trans that i tried using it on.
I give it a thumbs down. down
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Harbor Freight Standard Transmission floor lift [Re: TOMRR] #1964058
12/05/15 11:28 PM
12/05/15 11:28 PM
smyrna,tn
draginmopars Offline
smyrna,tn
I drilled holes in a 727 trans pan, bolted it to the jack
when pulling 727/518 the trans sits perfect in the pan,, no sliding around
I use mine for lots of projects.
holding a tire up
pulling a rear end
placing a rear end unto the springs
even makes a good roll around tool tray, when outside> drilling and de burring a block.
or doing brakes
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Harbor Freight Standard Transmission floor lift [Re: hemi71x] #1964089
12/06/15 12:16 AM
12/06/15 12:16 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Held my T56 6-speed just fine two weekends ago
2020 RAM 1500
Re: Harbor Freight Standard Transmission floor lift [Re: TOMRR] #1964147
12/06/15 01:37 AM
12/06/15 01:37 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I have one and have used the heck out of it. I've used it to R&R my 92 Getrac 360 5-spd in my 92 D350. That tranny weighs more than I do. I attached 2 metal bars on the sides to hold the tranny in place. Works great. Use an impact to raise it but not to lower it. Do that with a ratchet.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Harbor Freight Standard Transmission floor lift [Re: TOMRR] #1964159
12/06/15 02:04 AM
12/06/15 02:04 AM
BDW Offline
BDW  Offline
Brilliant idea of bolting a tranny pan to it. Wished I'd thought of that.
Small/slick working area and my tranny did slip off once and landed on my chest, ouch.
Re: Harbor Freight Standard Transmission floor lift [Re: hemi71x] #1964290
12/06/15 12:25 PM
12/06/15 12:25 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I borrowed one from my friend and it was cake to put the 4-speed into my car.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Harbor Freight Standard Transmission floor lift [Re: TOMRR] #1964297
12/06/15 12:37 PM
12/06/15 12:37 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://www.sears.com/craftsman-professio...la=00950191000P
that looks pretty slick! I probably don't get the car in the air as high as needed so I just use my motorcycle jack for trans work. Another good tip is that I use the worthless screw jack from my 2500 Ram to hold the engine up. Small, compact, won't bleed down.
Re: Harbor Freight Standard Transmission floor lift [Re: hemi71x] #1964308
12/06/15 12:54 PM
12/06/15 12:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That's like saying I bought a POS neon 10 years ago so they all suck. I can pretty much guarantee that the HF of today is nothing like the HF of 10 year ago, including the trans jacks.
Don't be the exception.
Re: Harbor Freight Standard Transmission floor lift [Re: hemi71x] #1964514
12/06/15 07:45 PM
12/06/15 07:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
they may have I bought one earlier this year and it worked ok , it's great if you are on your back , I used it under a lift ... that was interesting ... it involved some blocks of wood and a 55 gallon drum .
Re: Harbor Freight Standard Transmission floor lift [Re: TOMRR] #1964613
12/06/15 10:17 PM
12/06/15 10:17 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I also used the motorcycle jack..wished all wheels was a caster..it would if been easier
Re: Harbor Freight Standard Transmission floor lift [Re: TOMRR] #1964919
12/07/15 02:57 PM
12/07/15 02:57 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
[img]http://images11.palcdn.com/hlr-system/We...d2-56110847a5a6[/img]
I have one like this, used it lots with no problems.
