Harbor Freight Standard Transmission floor lift
#1963668
12/05/15 12:10 PM
12/05/15 12:10 PM
Posts: 1,013 LEE, MASS
TOMRR
LEE, MASS
Has any one used a Standard Transmission Floor Lift that Harbor Freight sells ? They are $99 and I have a 20% off coupon !!!
Thanks Tom C.
Re: Harbor Freight Standard Transmission floor lift
[Re: dvw]
#1963688
12/05/15 12:37 PM
12/05/15 12:37 PM
Posts: 20,176 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have this one and LOVE the heck out of it. I work without a lift so this really helps. As with most of their products I took it apart and cleaned the shavings out of it and applied grease to the screw and DON"T force it past its upper and lower limits. When it stops, stop. http://www.harborfreight.com/450-lb-low-lift-transmission-jack-61232.html
[Re: pittsburghracer]
#1963697
12/05/15 12:51 PM
12/05/15 12:51 PM
Posts: 7,664 IN
ahy
IN
I have one similar. Works great for car transmissions. I used it for the iron transmission on a '47 PW (heavy and high) and it was a bit wobbly. For PU's really need something wider and heavier.
[Re: TOMRR]
#1963986
12/05/15 08:45 PM
12/05/15 08:45 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Just bought one a few weeks ago...used it on a 46RE in my 99 Dodge Ram...worked great..
Had previously borrowed one and it worked just fine also.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1964032
12/05/15 10:39 PM
12/05/15 10:39 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
Well, I'm gonna be on the opposite side of the street with this one. Maybe they improved on the design of these things, when i owned one, bought one, 10 years ago, but it was the most worthless piece of schlitz that i bought from Harbor Freight. It wouldn't handle the Mopar 4 speed trans that i tried using it on. I give it a thumbs down.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: TOMRR]
#1964058
12/05/15 11:28 PM
12/05/15 11:28 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
I drilled holes in a 727 trans pan, bolted it to the jack when pulling 727/518 the trans sits perfect in the pan,, no sliding around I use mine for lots of projects. holding a tire up pulling a rear end placing a rear end unto the springs even makes a good roll around tool tray, when outside> drilling and de burring a block. or doing brakes
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: hemi71x]
#1964089
12/06/15 12:16 AM
12/06/15 12:16 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Well, I'm gonna be on the opposite side of the street with this one. Maybe they improved on the design of these things, when i owned one, bought one, 10 years ago, but it was the most worthless piece of schlitz that i bought from Harbor Freight. It wouldn't handle the Mopar 4 speed trans that i tried using it on. I give it a thumbs down. Held my T56 6-speed just fine two weekends ago
[Re: TOMRR]
#1964147
12/06/15 01:37 AM
12/06/15 01:37 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
I have one and have used the heck out of it. I've used it to R&R my 92 Getrac 360 5-spd in my 92 D350. That tranny weighs more than I do. I attached 2 metal bars on the sides to hold the tranny in place. Works great. Use an impact to raise it but not to lower it. Do that with a ratchet.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: hemi71x]
#1964290
12/06/15 12:25 PM
12/06/15 12:25 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Well, I'm gonna be on the opposite side of the street with this one. Maybe they improved on the design of these things, when i owned one, bought one, 10 years ago, but it was the most worthless piece of schlitz that i bought from Harbor Freight. It wouldn't handle the Mopar 4 speed trans that i tried using it on. I give it a thumbs down. I borrowed one from my friend and it was cake to put the 4-speed into my car.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: hemi71x]
#1964308
12/06/15 12:54 PM
12/06/15 12:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Well, I'm gonna be on the opposite side of the street with this one. Maybe they improved on the design of these things, when i owned one, bought one, 10 years ago, but it was the most worthless piece of schlitz that i bought from Harbor Freight. It wouldn't handle the Mopar 4 speed trans that i tried using it on. I give it a thumbs down. That's like saying I bought a POS neon 10 years ago so they all suck. I can pretty much guarantee that the HF of today is nothing like the HF of 10 year ago, including the trans jacks.
[Re: hemi71x]
#1964514
12/06/15 07:45 PM
12/06/15 07:45 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Well, I'm gonna be on the opposite side of the street with this one. Maybe they improved on the design of these things, when i owned one, bought one, 10 years ago, but it was the most worthless piece of schlitz that i bought from Harbor Freight. It wouldn't handle the Mopar 4 speed trans that i tried using it on. I give it a thumbs down. they may have I bought one earlier this year and it worked ok , it's great if you are on your back , I used it under a lift ... that was interesting ... it involved some blocks of wood and a 55 gallon drum .
