91 Cummins intercooler question #1963782
12/05/15 02:52 PM
12/05/15 02:52 PM
Spokane Valley WA
dan6412 Offline OP
dan6412  Offline OP
Spokane Valley WA
Im looking at a 91 Cummins non inintercooler ,truck to use for a engine swap project. Can I add an intercool with out any engine mods or should I find a inner cooled engine for my project ?
Project truck is a 70 D300 ramptruck.
Thanks Dan
Re: 91 Cummins inner cooler question [Re: dan6412] #1963805
12/05/15 03:45 PM
12/05/15 03:45 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
That would be "intercooler"....and the injectors are different, the turbo and tubing for an intercooled engine is different for sure. You don't need an intercooler to make any power if that's what you are thinking...lots of mods out there to make that Cummins go. JMO...
Re: 91 Cummins inner cooler question [Re: dan6412] #1963822
12/05/15 04:21 PM
12/05/15 04:21 PM
Spokane Valley WA
dan6412 Offline OP
dan6412  Offline OP
Spokane Valley WA
Sorry for the miss spelling Im posting from my phone and i just quit fighting auto correct and the little screen looking for longevit in a hauler/puller. Wasnt sure if the intercooler engin would be better over the non.
Re: 91 Cummins inner cooler question [Re: dan6412] #1963860
12/05/15 05:48 PM
12/05/15 05:48 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
The different injectors are more of a uning aid than a r3quirement to run the intercooler.
The intercooler helps keep exhaust temps in check under load, but proper tuning of the non ic engines avoids that too.
Angry white pureblood male
Re: 91 Cummins inner cooler question [Re: dan6412] #1963968
12/05/15 08:15 PM
12/05/15 08:15 PM
ky.
K
kenworth_goose Offline
K
ky.
The best running Cummins I've ever owned was a non intercooled.
Re: 91 Cummins inner cooler question [Re: dan6412] #1964054
12/05/15 11:13 PM
12/05/15 11:13 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I myself would not have one without the cooler. There is a reason why they added it and all of them have a cooler now. If your putting it in a ramp truck and plan on hauling loads I'd go with the intercooler. Get the core support and the bumper mount extensions and the install will be easier.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 91 Cummins intercooler question [Re: dan6412] #1964442
12/06/15 05:08 PM
12/06/15 05:08 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Yes.
But wait until you see the price on one. $$$ Wouldn't bother with a used one either: chances are very good it will have a leak. twocents
Mo' Farts
Moderated by "tbagger".
Re: 91 Cummins intercooler question [Re: dan6412] #1964798
12/07/15 10:26 AM
12/07/15 10:26 AM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
the radiator is also different. a non I/c radiator is wider.
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
