91 Cummins intercooler question
#1963782
12/05/15 02:52 PM
12/05/15 02:52 PM
Posts: 270 Spokane Valley WA
dan6412
Spokane Valley WA
Im looking at a 91 Cummins non inintercooler ,truck to use for a engine swap project. Can I add an intercool with out any engine mods or should I find a inner cooled engine for my project ? Project truck is a 70 D300 ramptruck.
Thanks Dan
Re: 91 Cummins inner cooler question
[Re: dan6412]
#1963860
12/05/15 05:48 PM
12/05/15 05:48 PM
Posts: 5,884 ohio
ruderunner
ohio
The different injectors are more of a uning aid than a r3quirement to run the intercooler.
The intercooler helps keep exhaust temps in check under load, but proper tuning of the non ic engines avoids that too.
Angry white pureblood male
[Re: dan6412]
#1964054
12/05/15 11:13 PM
12/05/15 11:13 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I myself would not have one without the cooler. There is a reason why they added it and all of them have a cooler now. If your putting it in a ramp truck and plan on hauling loads I'd go with the intercooler. Get the core support and the bumper mount extensions and the install will be easier.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: 91 Cummins intercooler question
[Re: dan6412]
#1964442
12/06/15 05:08 PM
12/06/15 05:08 PM
Posts: 6,007 Salem
Grizzly
Moparts Proctologist
Salem
Im looking at a 91 Cummins non inintercooler ,truck to use for a engine swap project. Can I add an intercool with out any engine mods Yes. But wait until you see the price on one. $$$ Wouldn't bother with a used one either: chances are very good it will have a leak.
Mo' Farts
Moderated by "tbagger".
[Re: dan6412]
#1964798
12/07/15 10:26 AM
12/07/15 10:26 AM
Posts: 4,696 enfield, CT
ViperDave
enfield, CT
the radiator is also different. a non I/c radiator is wider.
67 Dart GT Vert 273/904 72 Town & Country 440/727 90 D350 reg cab dually cummins 15 Scat Pack Challenger
