Broke an exhaust manifold stud on the collector end...
#1957099
11/24/15 03:38 PM
11/24/15 03:38 PM
Posts: 6,480 USA
Molloy
USA
This is on my 300 SRT8 with catalytic converter problems...
Grind flat and drill out, or are there other tricks?
Looks like it's pressed in. I suppose I could heat it up and beat on it?
Thanks for any suggestions.
Re: Broke an exhaust manifold stud on the collector end...
[Re: Molloy]
#1957125
11/24/15 04:04 PM
11/24/15 04:04 PM
Posts: 10,135 A Red State
SNK-EYZ
A Red State
Can you feel if there are threads on the top side of the stud? If there are no threads, then grind it flat, drill it out and tap it to thread it. That or drill it out and use a bolt and nut (which is what most cast iron manifolds use). The stud may have been welded in place on the factory headers like that. Edit: After doing an online google search of pictures of factory SRT headers I see some with no studs in the collector end making me thing that they are removable, as in threaded in. Grind, drill, tap is your best option.
[Re: SNK-EYZ]
#1957143
11/24/15 04:37 PM
11/24/15 04:37 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Can you feel if there are threads on the top side of the stud? If there are no threads, then grind it flat, drill it out and tap it to thread it. That or drill it out and use a bolt and nut (which is what most cast iron manifolds use). The stud may have been welded in place on the factory headers like that. Edit: After doing an online google search of pictures of factory SRT headers I see some with no studs in the collector end making me thing that they are removable, as in threaded in. Grind, drill, tap is your best option. Looks a 'yota stud that uses a torx socket. I agree with grind, drill, and tap. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: Molloy]
#1957451
11/25/15 01:17 AM
11/25/15 01:17 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have never heard of an exhaust stud being pressed or welded in. It looks per picture there is not enough of the stud to get a vise grip on to it so as stated above weld a nut on it, then heat the flange and turn it out. Might as well remove the other one also, heat the flange first, grip it with some good vise grips, pipe wrench or a stud removal tool. Replace with proper studs and brass nuts.
[Re: Molloy]
#1957783
11/25/15 05:30 PM
11/25/15 05:30 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
An experienced exhaust man would blow that out with a torch and never touch the threads in the manifold. Takes about a minute including lighting the torch.
[Re: GomangoCuda]
#1958229
11/26/15 11:06 AM
11/26/15 11:06 AM
Posts: 9,836 MI, usa
dvw
MI, usa
An experienced exhaust man would blow that out with a torch and never touch the threads in the manifold. Takes about a minute including lighting the torch. Very true, done a ton of them. But that's not for a beginner. Doug
