Broke an exhaust manifold stud on the collector end... #1957099
11/24/15 03:38 PM
11/24/15 03:38 PM
USA
Molloy Offline OP
Molloy  Offline OP
USA
This is on my 300 SRT8 with catalytic converter problems...
Grind flat and drill out, or are there other tricks?
Looks like it's pressed in. I suppose I could heat it up and beat on it?
Thanks for any suggestions.
Re: Broke an exhaust manifold stud on the collector end... [Re: Molloy] #1957114
11/24/15 03:54 PM
11/24/15 03:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"Grind flat and drill out, or are there other tricks?"
that...if you beat on it you might bend the flange.
Coming soon!!!!
Re: Broke an exhaust manifold stud on the collector end... [Re: Molloy] #1957125
11/24/15 04:04 PM
11/24/15 04:04 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Can you feel if there are threads on the top side of the stud?
If there are no threads, then grind it flat, drill it out and tap it to thread it.
That or drill it out and use a bolt and nut (which is what most cast iron manifolds use).
The stud may have been welded in place on the factory headers like that.
Edit:
After doing an online google search of pictures of factory SRT headers I see some with no studs in the collector end making me thing that they are removable, as in threaded in. shruggy
Grind, drill, tap is your best option.
Re: Broke an exhaust manifold stud on the collector end... [Re: SNK-EYZ] #1957143
11/24/15 04:37 PM
11/24/15 04:37 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Edit:
Looks a 'yota stud that uses a torx socket. I agree with grind, drill, and tap.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Broke an exhaust manifold stud on the collector end... [Re: Molloy] #1957272
11/24/15 07:42 PM
11/24/15 07:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Weld a nut to it. It'll come right out.
Doug
Re: Broke an exhaust manifold stud on the collector end... [Re: dvw] #1957433
11/25/15 12:33 AM
11/25/15 12:33 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Doug
iagree
Re: Broke an exhaust manifold stud on the collector end... [Re: Molloy] #1957451
11/25/15 01:17 AM
11/25/15 01:17 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have never heard of an exhaust stud being pressed or welded in. It looks per picture there is not enough of the stud to get a vise grip on to it so as stated above weld a nut on it, then heat the flange and turn it out. Might as well remove the other one also, heat the flange first, grip it with some good vise grips, pipe wrench or a stud removal tool. Replace with proper studs and brass nuts.
Re: Broke an exhaust manifold stud on the collector end... [Re: Molloy] #1957488
11/25/15 02:19 AM
11/25/15 02:19 AM
USA
Molloy Offline OP
Molloy  Offline OP
USA
Turns out it was threaded into the flange. I welded a nut to the remnant of the stud (full fusion too) but it just broke off when I tried to back it out. Ultimately had to drill it out. That sucked, but it's done...
Thanks guys
Re: Broke an exhaust manifold stud on the collector end... [Re: Molloy] #1957783
11/25/15 05:30 PM
11/25/15 05:30 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
An experienced exhaust man would blow that out with a torch and never touch the threads in the manifold. Takes about a minute including lighting the torch.
Re: Broke an exhaust manifold stud on the collector end... [Re: Molloy] #1958037
11/26/15 01:15 AM
11/26/15 01:15 AM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
next time weld a flat washer to the stud, then weld nut to washer. when cooling saturate with penetrating oil, let cool and remove
Re: Broke an exhaust manifold stud on the collector end... [Re: GomangoCuda] #1958229
11/26/15 11:06 AM
11/26/15 11:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Very true, done a ton of them. But that's not for a beginner.
Doug
Re: Broke an exhaust manifold stud on the collector end... [Re: Molloy] #1958241
11/26/15 11:20 AM
11/26/15 11:20 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Last one I was working on I ground it flat, cut the head off a bolt and welded the stud to the flange. Tried drilling it out but it was in an awkward spot to get a drill.
