Recommended stall verter makes. #1951440
11/15/15 05:55 AM
11/15/15 05:55 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
What make converters would you recommend for a street /sometime strip car making 450-475 hp?
Ive had bad luck with PTC....Any other suggested makes?
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Recommended stall verter makes. [Re: Moparmal] #1951463
11/15/15 09:25 AM
11/15/15 09:25 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Ultimate or ATI.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Recommended stall verter makes. [Re: Moparmal] #1951482
11/15/15 10:46 AM
11/15/15 10:46 AM
PA
Harry's Taxi 2 Offline
PA
Turbo-Action.
ATI will be fit and function, but likely be slower.
No direct experience with other brands.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Recommended stall verter makes. [Re: Harry's Taxi 2] #1951499
11/15/15 11:40 AM
11/15/15 11:40 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
PTC has a great rep,not so much with me.my ultimate vert has been in 3 diff cars and still works great.
Re: Recommended stall verter makes. [Re: Moparmal] #1951536
11/15/15 12:33 PM
11/15/15 12:33 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
Dynamic
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Recommended stall verter makes. [Re: Moparmal] #1951548
11/15/15 12:47 PM
11/15/15 12:47 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We use Turbo Action and have since 1977. Excellent quality.
www.turboaction.com
Nautilus Racing-
Re: Recommended stall verter makes. [Re: Moparmal] #1952013
11/15/15 11:41 PM
11/15/15 11:41 PM
Moparmal Offline OP
Moparmal  Offline OP
Where does TCI sit as far as quality?
Re: Recommended stall verter makes. [Re: Moparmal] #1952031
11/16/15 12:02 AM
11/16/15 12:02 AM
jersey
Spaceman Spiff Offline
jersey
The same place B&M does. down
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Recommended stall verter makes. [Re: Moparmal] #1952049
11/16/15 12:20 AM
11/16/15 12:20 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Total Crap Inside! I would not even dream of using them.
I have had very good luck with TA, and now with ATI.....ATI nailed it on my 605, and that was a tough one.
Re: Recommended stall verter makes. [Re: Moparmal] #1952080
11/16/15 12:42 AM
11/16/15 12:42 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
PTC, excellent to deal with and a great product.
Re: Recommended stall verter makes. [Re: Moparmal] #1952092
11/16/15 12:58 AM
11/16/15 12:58 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'm very happy with my Lupo - Dynamic. Reasonably priced and has been reliable and performed well for me.
Re: Recommended stall verter makes. [Re: Moparmal] #1952094
11/16/15 01:01 AM
11/16/15 01:01 AM
Moparmal Offline OP
Moparmal  Offline OP
Well its not the converter.....
Thank you MP.
Re: Recommended stall verter makes. [Re: Moparmal] #1952097
11/16/15 01:07 AM
11/16/15 01:07 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I always use the B&M round flexplate, they seem to hold up really well.
As far as converters, ATI always nails my combo and work awesome.
Re: Recommended stall verter makes. [Re: Moparmal] #1952166
11/16/15 03:57 AM
11/16/15 03:57 AM
Puyallup, WA
Puyallup, WA
Whatever happened there, its not the flexplates fault. Obviously something else caused that sort of failure. I once ruined a flexplate similarly, when the converter ballooned and forced the flexplate bolts into the pan rail.
Re: Recommended stall verter makes. [Re: Moparmal] #1952182
11/16/15 05:02 AM
11/16/15 05:02 AM
Moparmal Offline OP
Moparmal  Offline OP
All the bolts were still in place, and 1 of the 4 was still torqued to spec....the others were still tight but not to spec obviously because of the fracturing.
The car has been driven at road speeds for three weeks making a slight knocking noise from the bell housing since I last raced it.
I suspected a loose crank bolt or several ...but they were all tight.
Motor is internally balanced..and the converter was working fine.
So not really sure what else it could be...but theres a reason the ATI plate is 1mm thicker and has extra 'bulk' in the exact points this mp plate broke.......
