Recommended stall verter makes.
#1951440
11/15/15 05:55 AM
11/15/15 05:55 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
What make converters would you recommend for a street /sometime strip car making 450-475 hp?
Ive had bad luck with PTC....Any other suggested makes?
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Recommended stall verter makes.
[Re: Moparmal]
#1951482
11/15/15 10:46 AM
11/15/15 10:46 AM
Posts: 287 PA
Harry's Taxi 2
PA
Turbo-Action.
ATI will be fit and function, but likely be slower.
No direct experience with other brands.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Moparmal]
#1952013
11/15/15 11:41 PM
11/15/15 11:41 PM
Moparmal
Where does TCI sit as far as quality?
[Re: Moparmal]
#1952031
11/16/15 12:02 AM
11/16/15 12:02 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Where does TCI sit as far as quality? The same place B&M does.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Moparmal]
#1952049
11/16/15 12:20 AM
11/16/15 12:20 AM
Posts: 12,392 Taxes & Virus's R-US, NY
Dragula
Where does TCI sit as far as quality? Total Crap Inside! I would not even dream of using them. I have had very good luck with TA, and now with ATI.....ATI nailed it on my 605, and that was a tough one.
[Re: Moparmal]
#1952092
11/16/15 12:58 AM
11/16/15 12:58 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I'm very happy with my Lupo - Dynamic. Reasonably priced and has been reliable and performed well for me.
[Re: Moparmal]
#1952094
11/16/15 01:01 AM
11/16/15 01:01 AM
Moparmal
Well its not the converter..... Thank you MP.
[Re: Moparmal]
#1952097
11/16/15 01:07 AM
11/16/15 01:07 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I always use the B&M round flexplate, they seem to hold up really well.
As far as converters, ATI always nails my combo and work awesome.
[Re: Moparmal]
#1952166
11/16/15 03:57 AM
11/16/15 03:57 AM
StealthWedge67
Puyallup, WA
Whatever happened there, its not the flexplates fault. Obviously something else caused that sort of failure. I once ruined a flexplate similarly, when the converter ballooned and forced the flexplate bolts into the pan rail.
[Re: Moparmal]
#1952182
11/16/15 05:02 AM
11/16/15 05:02 AM
Moparmal
All the bolts were still in place, and 1 of the 4 was still torqued to spec....the others were still tight but not to spec obviously because of the fracturing.
The car has been driven at road speeds for three weeks making a slight knocking noise from the bell housing since I last raced it.
I suspected a loose crank bolt or several ...but they were all tight.
Motor is internally balanced..and the converter was working fine.
So not really sure what else it could be...but theres a reason the ATI plate is 1mm thicker and has extra 'bulk' in the exact points this mp plate broke.......
