Caltrac adjustment........... #1949764
11/12/15 01:44 AM
11/12/15 01:44 AM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I normally run a 315/60 M/T Drag Radial and the track that I a running at now ( Because the rest are closed)I can't hook with the radials. I put my 29.5/10.5 W's on it and it hooks great but it goes straight to the right when I leave the line. I checked the tire diameter and they are with in a 1/4 in. I switched sides with the tires and it still goes to the right. The rear suspension is Caltrac bars with stock leaf springs. Why would it go straight with the radials and go to the right so bad that I have to let off the gas or it will hit the tree or wall if I stay in it. It snatches the front tires straight up and goes to the right.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Caltrac adjustment........... [Re: D-50] #1949789
11/12/15 02:40 AM
11/12/15 02:40 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Maybe the dead hook of a radial hold your rear leafs at a different angle or preload. With the slicks it not holding as hard. Is it possible that the right tire is spinning? Topping out a shock, not holding a adjustment. I would try adjusting preload on the bars.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Caltrac adjustment........... [Re: D-50] #1949807
11/12/15 04:06 AM
11/12/15 04:06 AM
SoCal
Brian Hafliger Offline
SoCal
do you have any preload in the bars?
Brian Hafliger
Re: Caltrac adjustment........... [Re: D-50] #1950057
11/12/15 05:19 PM
11/12/15 05:19 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
We generally add one flat of preload onto the side its driving to.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Caltrac adjustment........... [Re: D-50] #1950138
11/12/15 08:47 PM
11/12/15 08:47 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
First I added about a 1/2 lb of air in the right slick. It did not help. Then I put about a 1/4 turn of preload on the right side. It might of helped a little. Then I backed off a little on the left side and it did not change. I have a short video of one attempt. I will see if I can load it on here. I have the bars in the top hole I might move them to the lower hole and start over with the left bar just touching and the the right with a 1/8 -1/4 turn preload.
Re: Caltrac adjustment........... [Re: D-50] #1950150
11/12/15 09:17 PM
11/12/15 09:17 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Don't back off the left side. Keep adding one flat at per run on the right side until it straightens out.
Re: Caltrac adjustment........... [Re: D-50] #1950154
11/12/15 09:31 PM
11/12/15 09:31 PM
johnnycuda Offline
johnnycuda  Offline
As a baseline, we set both sides at 1/4 turn of preload, driver in the seat, the lower hole will hit the tire softer at launch.
Re: Caltrac adjustment........... [Re: D-50] #1950211
11/12/15 11:24 PM
11/12/15 11:24 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Ok this is a short video from Sunday..Maybe this will work.
https://youtu.be/CZ9-5tADMjY
Re: Caltrac adjustment........... [Re: D-50] #1950508
11/13/15 02:44 PM
11/13/15 02:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Is the car lower on the dr. side at rest? I really feel you`re fighting things due to the multi-leafs myself and Cal-trac springs would fix a LOT if not all of the problems I see on the vid.......
Re: Caltrac adjustment........... [Re: D-50] #1950711
11/13/15 09:00 PM
11/13/15 09:00 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
It sets level at rest and goes stratght as a arrow with the Drag Radials on it. The springs have 2 leafs. This picture is with Drag Radials. On the video it had 10.5/29.5 W's on it.
Re: Caltrac adjustment........... [Re: D-50] #1950850
11/14/15 01:02 AM
11/14/15 01:02 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I am sure it's a adjustment, but look it over real good for a broken part. It turning right really bad.
Re: Caltrac adjustment........... [Re: D-50] #1951251
11/14/15 10:01 PM
11/14/15 10:01 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Break out the tape measure and the magnifying glass I'm betting something is bent or broken. Or the leaf springs are possibly dead
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Caltrac adjustment........... [Re: 1967dartgt] #1952244
11/16/15 11:55 AM
11/16/15 11:55 AM
an8sec70cuda Offline
iagree Make sure the perches on your rearend aren't twisted.
CHIP
'06 GMC 2500HD LBZ Duramax
