Caltrac adjustment...........
#1949764
11/12/15 01:44 AM
11/12/15 01:44 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I normally run a 315/60 M/T Drag Radial and the track that I a running at now ( Because the rest are closed)I can't hook with the radials. I put my 29.5/10.5 W's on it and it hooks great but it goes straight to the right when I leave the line. I checked the tire diameter and they are with in a 1/4 in. I switched sides with the tires and it still goes to the right. The rear suspension is Caltrac bars with stock leaf springs. Why would it go straight with the radials and go to the right so bad that I have to let off the gas or it will hit the tree or wall if I stay in it. It snatches the front tires straight up and goes to the right.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Caltrac adjustment...........
[Re: D-50]
#1949789
11/12/15 02:40 AM
11/12/15 02:40 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Maybe the dead hook of a radial hold your rear leafs at a different angle or preload. With the slicks it not holding as hard. Is it possible that the right tire is spinning? Topping out a shock, not holding a adjustment. I would try adjusting preload on the bars.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: D-50]
#1949807
11/12/15 04:06 AM
11/12/15 04:06 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
do you have any preload in the bars?
Brian Hafliger
[Re: D-50]
#1950057
11/12/15 05:19 PM
11/12/15 05:19 PM
Posts: 860 lancaster,california
johnnycuda
We generally add one flat of preload onto the side its driving to.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: D-50]
#1950138
11/12/15 08:47 PM
11/12/15 08:47 PM
D-50
North, Alabama
First I added about a 1/2 lb of air in the right slick. It did not help. Then I put about a 1/4 turn of preload on the right side. It might of helped a little. Then I backed off a little on the left side and it did not change. I have a short video of one attempt. I will see if I can load it on here. I have the bars in the top hole I might move them to the lower hole and start over with the left bar just touching and the the right with a 1/8 -1/4 turn preload.
[Re: D-50]
#1950150
11/12/15 09:17 PM
11/12/15 09:17 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
First I added about a 1/2 lb of air in the right slick. It did not help. Then I put about a 1/4 turn of preload on the right side. It might of helped a little. Then I backed off a little on the left side and it did not change. I have a short video of one attempt. I will see if I can load it on here. I have the bars in the top hole I might move them to the lower hole and start over with the left bar just touching and the the right with a 1/8 -1/4 turn preload. Don't back off the left side. Keep adding one flat at per run on the right side until it straightens out.
[Re: D-50]
#1950154
11/12/15 09:31 PM
11/12/15 09:31 PM
johnnycuda
As a baseline, we set both sides at 1/4 turn of preload, driver in the seat, the lower hole will hit the tire softer at launch.
[Re: D-50]
#1950211
11/12/15 11:24 PM
11/12/15 11:24 PM
D-50
North, Alabama
Ok this is a short video from Sunday..Maybe this will work. https://youtu.be/CZ9-5tADMjY
[Re: D-50]
#1950508
11/13/15 02:44 PM
11/13/15 02:44 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Is the car lower on the dr. side at rest? I really feel you`re fighting things due to the multi-leafs myself and Cal-trac springs would fix a LOT if not all of the problems I see on the vid.......
[Re: D-50]
#1950711
11/13/15 09:00 PM
11/13/15 09:00 PM
D-50
North, Alabama
It sets level at rest and goes stratght as a arrow with the Drag Radials on it. The springs have 2 leafs. This picture is with Drag Radials. On the video it had 10.5/29.5 W's on it.
[Re: D-50]
#1950850
11/14/15 01:02 AM
11/14/15 01:02 AM
1967dartgt
Hilltown Pa
I am sure it's a adjustment, but look it over real good for a broken part. It turning right really bad.
[Re: D-50]
#1951251
11/14/15 10:01 PM
11/14/15 10:01 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Break out the tape measure and the magnifying glass I'm betting something is bent or broken. Or the leaf springs are possibly dead
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: 1967dartgt]
#1952244
11/16/15 11:55 AM
11/16/15 11:55 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I am sure it's a adjustment, but look it over real good for a broken part. It turning right really bad. Make sure the perches on your rearend aren't twisted.
