Which GEARS/TIRES do you use ? #194961
01/16/09 08:38 AM
01/16/09 08:38 AM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hi,
could you tell me which gears and tires do you use for racing ? Weight of the car, 60' and ET ?
BR,
Fernando
1973 Brasilian Dart
E100, boosted 390"
Re: Which GEARS/TIRES do you use ? [Re: dart_73_br] #194962
01/16/09 09:36 AM
01/16/09 09:36 AM
PA
ajcasini Offline
ajcasini  Offline
PA
3650lb Roadrunner
28x9x15 MT
4.11 Gear
ET 11.0's @ 120
60' 1.52
Shift RPM 6000
Trap RPM 6100
AJ
Re: Which GEARS/TIRES do you use ? [Re: ajcasini] #194963
01/16/09 11:19 AM
01/16/09 11:19 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
3300lbs
31*13
4.30
727
1.35 60'
6.06@112mph
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Which GEARS/TIRES do you use ? [Re: dart_73_br] #194964
01/16/09 12:11 PM
01/16/09 12:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
72 dart 3140lbs. 4.11 richmond gears w/Hoosier 29x13.5 QTP`S........my sig says it all.
Re: Which GEARS/TIRES do you use ? [Re: dart_73_br] #194965
01/16/09 12:36 PM
01/16/09 12:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
2405# 4.56 gear with 13.2x31 tire, 1.19 60' with
the rest below
Re: Which GEARS/TIRES do you use ? [Re: dart_73_br] #194966
01/16/09 01:11 PM
01/16/09 01:11 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
4.10 gear(stock axles and sure grip)
30x9 Hoosier
3500#
1.53 60ft
11.30's
Re: Which GEARS/TIRES do you use ? [Re: racerAL] #194967
01/16/09 01:21 PM
01/16/09 01:21 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
3200lb Duster
29.5x13.5x15 MT
4.56 Gear
ET 11.30's @ 116
60' 1.51
Shift RPM 6000
Trap RPM 6400
Re: Which GEARS/TIRES do you use ? [Re: DusterKid] #194968
01/16/09 02:52 PM
01/16/09 02:52 PM
3400 lb Duster with driver, 3:91 gears, 315x60x15 ET Street Radails, 10:34 ET at 128.6 mph. I have used 3:73, 4:10 and the 3:91 in the same car with almost identicle results The motor is 518 C.I. pump gas with some good parts so that can make a difference, 700+ hp and 740+ ft lbs torque last time on the engine dyno
Re: Which GEARS/TIRES do you use ? [Re: Cab_Burge] #194969
01/16/09 02:58 PM
01/16/09 02:58 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Old cuda, ran a 28" MT street radial, 3.91 gear, 1.36 60' 9.98 @ 134 mph in street trim...Phill
Re: Which GEARS/TIRES do you use ? [Re: 9 Sec Phill] #194970
01/16/09 03:09 PM
01/16/09 03:09 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
4.30 gear with Mosir axles and spool, 29.5X10.5 M/T slick
Consistent 11.40's with 1.56 60 foot, 3000 lb car with 360 on throttle.
Re: Which GEARS/TIRES do you use ? [Re: Cab_Burge] #194971
01/16/09 03:13 PM
01/16/09 03:13 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
What IŽm thinking about... IŽbe a 3:73 gears on a 318 aproximatly 450hp.. I donŽt have that torque so.. changing 3:73 to 4:10 will have a great effect on my ET ?
Have simulated it on software Drag2003 and canŽt see much improvement...
Fernando
1973 Brasilian Dart
E100, boosted 390"
Re: Which GEARS/TIRES do you use ? [Re: 9 Sec Phill] #194972
01/16/09 03:22 PM
01/16/09 03:22 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
68 Dart 3150lbs ( see signature) best E.T. 10.40, best MPH 126.42, best 60 ft 1.40 with 4.88s Hoosier Radial slicks 10x28 or Hoosier bias slicks 10.5 x 29.5
Now throttle stopped down to run 11.50s at 114-115 mph 1.53-56 60ft Hoosier QTPs 29 x 11.5 putting 4.56s back in to try and run 116-117 mph.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Which GEARS/TIRES do you use ? [Re: 11secdart] #194973
01/16/09 03:58 PM
01/16/09 03:58 PM
aotearoa
rebel Online content
rebel  Online Content
aotearoa
2950lbs 4.8 richmond gears 32x14 et drags 1.34 60' 9.70@138mph @ 7200 cross the stripe. 5500 stall.
Re: Which GEARS/TIRES do you use ? [Re: rebel] #194974
01/16/09 04:09 PM
01/16/09 04:09 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
3120, 4.56, 32x14.5, 1.34 60', 9.38 @ 144.
Re: Which GEARS/TIRES do you use ? [Re: dart_73_br] #194975
01/16/09 04:13 PM
01/16/09 04:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Fernando
You'll see a difference specially with a 318. Since
you basicly dont have much torque you need the steeper
gear to use it as a torque multiplier, you'll be
spending more time at the slower speeds
Re: Which GEARS/TIRES do you use ? [Re: MR_P_BODY] #194976
01/16/09 05:52 PM
01/16/09 05:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
4.30 gears
29 x 11.5 Hoosier Quick Time Pro's
3700 lb 63 Sport Fury street car
1.58 best 60
11.50's @ 116
shift at 6200 trap at 6300 , Ron
Re: Which GEARS/TIRES do you use ? [Re: MR_P_BODY] #194977
01/16/09 09:42 PM
01/16/09 09:42 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
you'll be
About the torque I agree,,, but IŽll spend more time at the slower speeds... is it good ?!
By the way... anybody drives those 4:11+ gears on street or just at the strip!?
Re: Which GEARS/TIRES do you use ? [Re: dart_73_br] #194978
01/16/09 09:44 PM
01/16/09 09:44 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
street and strip
4.10s and 28 12.5 15 mt,s street tires
4.10s and 29.5 10.5 15 mt,s slicks
1.39 9.85 - 137 mph
Re: Which GEARS/TIRES do you use ? [Re: dart_73_br] #194979
01/16/09 10:04 PM
01/16/09 10:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you look at the time you spend trying to come
off the line to lets say 200' you spend most of the
track time there(per given distance), steeper gears
accellerates harder quicker to move you that distance
Re: Which GEARS/TIRES do you use ? [Re: dart_73_br] #194980
01/16/09 11:39 PM
01/16/09 11:39 PM
PA
ajcasini Offline
ajcasini  Offline
PA
I have had the 4.11's on the street with some 255's and was at about 3200 RPM and running about 55 - 60 MPH.
AJ
