Which GEARS/TIRES do you use ?
#194961
01/16/09 08:38 AM
01/16/09 08:38 AM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
Hi,
could you tell me which gears and tires do you use for racing ? Weight of the car, 60' and ET ?
BR, Fernando
1973 Brasilian Dart E100, boosted 390"
Re: Which GEARS/TIRES do you use ?
[Re: ajcasini]
#194963
01/16/09 11:19 AM
01/16/09 11:19 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
3300lbs 31*13 4.30 727 1.35 60' 6.06@112mph
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: dart_73_br]
#194966
01/16/09 01:11 PM
01/16/09 01:11 PM
Posts: 535 Ohio
racerAL
Ohio
4.10 gear(stock axles and sure grip) 30x9 Hoosier 3500# 1.53 60ft 11.30's
[Re: DusterKid]
#194968
01/16/09 02:52 PM
01/16/09 02:52 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
3400 lb Duster with driver, 3:91 gears, 315x60x15 ET Street Radails, 10:34 ET at 128.6 mph. I have used 3:73, 4:10 and the 3:91 in the same car with almost identicle results The motor is 518 C.I. pump gas with some good parts so that can make a difference, 700+ hp and 740+ ft lbs torque last time on the engine dyno
[Re: 9 Sec Phill]
#194972
01/16/09 03:22 PM
01/16/09 03:22 PM
Posts: 4,963 new jersey usa
11secdart
new jersey usa
68 Dart 3150lbs ( see signature) best E.T. 10.40, best MPH 126.42, best 60 ft 1.40 with 4.88s Hoosier Radial slicks 10x28 or Hoosier bias slicks 10.5 x 29.5 Now throttle stopped down to run 11.50s at 114-115 mph 1.53-56 60ft Hoosier QTPs 29 x 11.5 putting 4.56s back in to try and run 116-117 mph.
[Re: 11secdart]
#194973
01/16/09 03:58 PM
01/16/09 03:58 PM
Posts: 4,647 aotearoa
rebel
aotearoa
2950lbs 4.8 richmond gears 32x14 et drags 1.34 60' 9.70@138mph @ 7200 cross the stripe. 5500 stall.
[Re: dart_73_br]
#194975
01/16/09 04:13 PM
01/16/09 04:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What IŽm thinking about... IŽbe a 3:73 gears on a 318 aproximatly 450hp.. I donŽt have that torque so.. changing 3:73 to 4:10 will have a great effect on my ET ? Have simulated it on software Drag2003 and canŽt see much improvement... Fernando
You'll see a difference specially with a 318. Since you basicly dont have much torque you need the steeper gear to use it as a torque multiplier, you'll be spending more time at the slower speeds
[Re: MR_P_BODY]
#194977
01/16/09 09:42 PM
01/16/09 09:42 PM
dart_73_br
Sao Paulo, Brazil
About the torque I agree,,, but IŽll spend more time at the slower speeds... is it good ?!
By the way... anybody drives those 4:11+ gears on street or just at the strip!?
[Re: dart_73_br]
#194978
01/16/09 09:44 PM
01/16/09 09:44 PM
Posts: 5,617 long island NY
Ari440
long island NY
street and strip
4.10s and 28 12.5 15 mt,s street tires
4.10s and 29.5 10.5 15 mt,s slicks
1.39 9.85 - 137 mph
[Re: dart_73_br]
#194980
01/16/09 11:39 PM
01/16/09 11:39 PM
Posts: 686 PA
ajcasini
PA
I have had the 4.11's on the street with some 255's and was at about 3200 RPM and running about 55 - 60 MPH.
AJ
