Re: 95 stratus won't crank after small fender bender
[Re: it's Bob]
#1930059
10/11/15 10:38 AM
10/11/15 10:38 AM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
Is there a G force cut out/shutdown switch in this car? Do you think the bump was hard/firm enough for it to activate it if there is one there? Can you tell if the fuel pump is running when you turn the key to start? If no fuel pump sounds/running you might have activated the G/shut down switch. Just another thought. No such switch on a mopar
[Re: gtx6970]
#1931163
10/12/15 11:56 PM
10/12/15 11:56 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
There are 2 fuse boxes under hood ( they are side by side. Ck all fuses and relays in both.)
The battery grounds to the stud on top of the left front strut tower , remove both leads and clean them . It also goes down and grounds to the left side of the transmission case under the left side trans mount bolt
Positive lead goes to a stud on top of the fuse/relay bank
The trans linkage and electrical connector are on the drivers side. make sure it didnt break the plug off where it connects to the trans ( seen it before on accident victims)
There is no enertia swich on a stratus This made me remember that he is right about the two PDC boxes which means Power Distribution Center as thats what Mopar calls them under the hood and they call them fuse boxes inside the car. But the two under the hood should be next to each other and one of them is not easy to notice as I believe the battery cable just about goes over its lid. But I remember very well the Stratus had a fuse under the hood for the starter solenoid circuit so make sure you find and check both boxes under the hood. Ron
[Re: 6T6Cuda]
#1932720
10/15/15 05:57 PM
10/15/15 05:57 PM
gtx6970
It's a dry heat
It looks like this just screws in from the outside - I assume I don't need to pull the trans pan?
correct I'll send you a bill. lol
