95 stratus got in small fender bender on left front. Now it won't crank. All lights work battery good, if you have the headlights on they don't dim when cranking, it does not do anything like it is.not in park.
Is there an inertal switch for the starter? All engine fuses good. Haynes manual said something about a disable link, but I did not see one. No power to starter sonoid when cranking. Sounds like neutral safety switch or some safety system
Any thoughts?
