decode my timeslip
#1920942
09/28/15 12:00 AM
09/28/15 12:00 AM
Posts: 314 Medina, OH
dart440_72
Medina, OH
So I have been chasing the 10's for years and finally did it!This past Wednesday I went a 10.66 at 124MPH. I think the combo has more in it. I just have to figure it out. The car is a 72 Dart with a 500" low deck. Indy SR. Solid cam 650ish, 275@50. compression is around 13.5:1. 727 with an 8" converter flashing at 5400. rear gears are 4.33. I'm not sure if that converter is flashing too high. That is what the company recommended. I also don't have a clue on how to post pics on this site. Not sure if you will be able to view this or not. Thanks in advance. [img:left] https://drive.google.com/file/d/0B89l7x47jBZVcU91NU5FVXZrVHc/view?usp=sharing[/img]
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: decode my timeslip
[Re: dart440_72]
#1921094
09/28/15 11:11 AM
09/28/15 11:11 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Looks acceptable up to the 1/8,,,,appears lazy from the 1/8 to the 1/4. Might need more fuel or fuel system upgrades.
If you like drag racing, support your local track.
[Re: dart440_72]
#1921095
09/28/15 11:14 AM
09/28/15 11:14 AM
Posts: 7,506 Az
Crizila
Az
Rear tire diameter at what rpm are you shifting at?
Fastest 300
[Re: Crizila]
#1921098
09/28/15 11:20 AM
09/28/15 11:20 AM
dart440_72
Medina, OH
Rear tire is a 28x10.5. I was shifting at 6400.
[Re: dart440_72]
#1921209
09/28/15 02:57 PM
09/28/15 02:57 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I would work on the 60 ft. times, try different stall speeds, air pressures, shock settings and so on As far as the 1/4 MPH have you tried jetting the carb. up fat enough to slow the MPH down? If not try that, if you can't jet it fat enough to slow the MPH down in the 1/4you need to fix the fuel delivery system Let us know what you do and the results BTW, are your SR 440 port or Max Wedge size? If 440 the porting them to the M.W. size will help also, more air and fuel equals more power
[Re: dart440_72]
#1921451
09/28/15 08:56 PM
09/28/15 08:56 PM
dart440_72
Medina, OH
Thanks for all the responses. It really helps! My intake is a 4150 M1 Single plane with a 1000CFM Demon RS on it. Not sure on the jets and squirters. I do know that my AFR is around 11-12:1 from the wideband. I really wanted to confirm that the car had some more in it. It seemed like it did. Now I just have to sort it out.
The heads don't have max wedge ports yet.
Thanks again
[Re: dart440_72]
#1921460
09/28/15 09:16 PM
09/28/15 09:16 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Your 60 ft. should be a lot better. If you get it better you would pick up. My full interior 71 Demon with a stock stroke 360 with ported stock heads with the same gears had a 1.49 60 ft. and ran a best of 6.99 in the 1/8.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: dart440_72]
#1921466
09/28/15 09:32 PM
09/28/15 09:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks again At 11-12 on AFR your fat... try leaning it down EDIT watch the MPH to get the max MPH when jetting... ET is the chassis
